1999 Infiniti I30 electrical problems
Old Jan 28, 2019 | 08:10 AM
ZJLS's Avatar
My 1999 Infiniti i30 is slowly getting worse . First the blinkers stopped working, the hazards and all lights still work, but the switch won’t work.
Then the radio, clock, and cigarette lighter all went out and stopped working. Also the windshield wipers stopped working.
I need help, what is my problem? They all went out within the last few days.
Old Jan 28, 2019 | 09:22 AM
Turbobink's Avatar
You need to start by checking your battery's condition and the charging status of your alternator.
With the car running, are any dash lights illuminated?
Old Jan 28, 2019 | 09:32 AM
ZJLS's Avatar
No dash lights are on, for a while the e-brake light flickered and so did the battery light. Then the blinkers went out. After that a couple days later the windshield wipers, radio, clock, and cigarette lighter stopped working. I had just replaced the alternator like 2 or 3 months ago.
Old Jan 28, 2019 | 09:43 AM
Turbobink's Avatar
Originally Posted by ZJLS
... for a while the e-brake light flickered and so did the battery light.
These lights appearing together is the classic indicator of a failing alternator.
I'm thinking that your battery and alternator tests will reveal that your battery is inadequately charged due to a failing alternator.
Old Jan 28, 2019 | 10:10 AM
ZJLS's Avatar
Thats Crazy, so things will just stop working when the alternator is failing like that?
Old Jan 28, 2019 | 10:36 AM
ZJLS's Avatar
so the radio, windshield wipers, clock and cigarette lighter are working again.
The blinkers still till Don’t work so do you know what that could be? Because the blinkers don’t work, but the hazards do
Old Jan 28, 2019 | 03:07 PM
DennisMik's Avatar
A bad hazard flasher switch will do that.
Old Jan 30, 2019 | 10:21 AM
reallywildstuff's Avatar
You should take the battery out of the car and have it tested on a bench.
If the battery is broken you'll never be able to figure out if your 3 month alternator is still working correctly or not. And, vice versa.
Once you've baselined the battery: you should observe 14.4V on the alternator pole with the engine running.
https://maxima.org/forums/4th-genera...new-one-2.html
3randon
30
Apr 14, 2013 01:20 PM
96maxi
Feb 16, 2011 05:46 PM
paulsfds
26
Dec 7, 2005 01:15 PM
geenowalker
Jul 19, 2005 10:04 AM
Mad-Marcus
Sep 9, 2004 09:09 AM
