Weird smog test fail
Old Apr 27, 2019 | 03:44 PM
Poopberries's Avatar
My 2001 Infiniti I30 sailed through all the smog tests here in Cali, save for one. Per the test: "Your vehicle failed the Smog Check inspection due to the fact that the vehicle's on-board computer system has not completed the emissions system's self-checks."
The test further states "OBD Monitors Not ready: Catalyst"
As a side note, my car recently had the rear main seal replaced. Is it possible that the mechanic disconnected something having to do with this problem?
Old Apr 29, 2019 | 06:00 PM
DennisMik's Avatar
How long after the rear main seal was replaced that you took the car to have it smogged? Depending on exactly how he replaced the seal, he may have disconnected the oxygen sensors, started the car, got a check engine light and then corrected it. This leaves the car in a not ready mode . It takes several days/a week of driving for things to become "ready" again. It depends on how you drive.
Old Apr 29, 2019 | 09:22 PM
Apparently I was driving too fast, then! But to answer your question, I had driven 2100 miles before I took the car to be smogged. The drive cycle to reinstate the OBD monitor involves top speeds of 55 mph, which will get you run over in CA!
Old May 3, 2019 | 11:07 AM
JvG's Avatar
JvG
I'm guessing that the 55 mph is due to the national speed limit when the car was designed. I would assume that speeds over 55 should be ok too.
The mechanic probably disconnected the battery while working on the car.
Old May 3, 2019 | 04:23 PM
That’s probably a likely scenario. In any case, the smog test is passed, the car is running great, and I’m hoping that it runs well for several tens of thousands of miles.
The only real problem that I’ve had with the car over the course of ownership is the catalytic converter going out twice, which is a very expensive repair when replaced. I will likely try a workaround solution if it happens again, but I sure would like it to prevent it from happening again, if possible.
aembleton
Jul 28, 2019 08:41 PM
zskot75
Nov 26, 2018 09:45 AM
Chrono
Mar 23, 2013 07:11 AM
godlyone
20
Jul 21, 2009 08:33 PM
2000MaxSE
Dec 21, 2000 08:20 PM
