2004 I35 cylinder 2 misfire
Old Nov 15, 2023 | 06:20 AM
blkmax1's Avatar
Trying to figure out why a friends 04 i35 had a miss on cylinder 2.? He said he was driving to work and check engine light came on then soon after the car started missing. Changed plugs, and coils still missing. Any advice guys?
Old Nov 15, 2023 | 12:10 PM
OEM spec spark plugs and coilpacks? It's likely a failing injector. Luckily cylinder 2 is easy to get to. What was the engine code when the codes were pulled?
Old Nov 16, 2023 | 12:41 PM
blkmax1's Avatar
Code 0302 cylinder 2 misfire. I changed the injector still misfiring
Old Nov 16, 2023 | 01:26 PM
Used, rebuilt or new? Don't rule out that the new injector is still faulty. I once had a misfire, replace the injector with a refurbished one and "flow tested" only to have ongoing misfire issues. Replaced the injector again, and the misfire went away.
It can only be 3 things. Spark plug, coilpack, or injector. Swap Coilpack 2 with coilpack 4 and see if the code moves to cylinder 4. If so, it's your coilpack and not your injector.
Old Nov 16, 2023 | 06:52 PM
blkmax1's Avatar
Owner bought new aftermarket coils. I’m going to swap coil packs tomorrow and see. Also I’m going to pull spark plugs. I don’t know what else to test for besides compression
blkmax1's Avatar
Also injectors are reman and tested
Old Nov 16, 2023 | 10:31 PM
Oh boy, our cars are picky and seem to only like OEM spec coilpacks. Let's see what happens when you swap coilpacks. Pull the sparkplug and check for condition, and for crap stuck at electrode.
Old Nov 16, 2023 | 10:32 PM
Like I said, don't rule out that the "new" injector could be bad.
Old Nov 17, 2023 | 06:01 AM
blkmax1's Avatar
Ok thanks I’ll swap coils and see what happens
Old Nov 17, 2023 | 07:08 AM
blkmax1's Avatar
Old Nov 17, 2023 | 07:09 AM
blkmax1's Avatar
The plug from cylinder 2 is clean and other plugs look slightly worn. What isn’t cylinder 2 getting correctly
Old Nov 17, 2023 | 08:43 AM
Yeah, but you just recently changed the spark plug in cylinder 2. Were any miles put on the car since the replacement?
Old Nov 17, 2023 | 08:44 AM
Also, here is a good chart for reading spark plugs.
https://ngksparkplugs.com/en/resources/read-spark-plug
Old Nov 17, 2023 | 10:07 AM
blkmax1's Avatar
Found the issue someone replaced the coil harness with an aftermarket one. I’m going to cut a factory one off and replace it. Also remove intake and replace injectors and plugs with OEM coils and ngk plugs. Owner had Bosch in there smdh
Old Nov 17, 2023 | 11:09 AM
Nice detective work.
I was gonna say, wha'ts with the Bosch plugs? NGK all the way.
Old Nov 17, 2023 | 03:23 PM
blkmax1's Avatar
Yes what kind should I go with for best performance and i appreciate the help
Old Feb 6, 2024 | 04:37 PM
nick's Avatar
VQ engines work best with OEM plugs (NGK)
IloveI35
Aug 30, 2024 08:52 AM
WaarrEagle
Feb 16, 2005 09:54 PM
saxiemaxy
Dec 10, 2004 10:48 AM
HotHotHot
48
Dec 5, 2003 04:33 PM
LucentAUTO
Apr 10, 2003 10:08 AM
