IACV hose
IACV hose
Where do you source or buy replacement IACV hose for a 1997 Infiniti I30? Usual silicon or heater hose are just a bit too soft for this.
Seems a commonly broken piece leading to rough idle and engine stalls.
@wezmykat and Wizard, thanks for pointers. The problem I have is I've been to Oreillys and back with a heater hose that is definitely not an IACV hose. On rockauto I can locate IACV, but also no IACV hose. What keywords/product number shall I search for?
So on rock auto, stuff that is not vehicle-specific (can be used on more than one vehicle) will not be found under the car itself
It will be located under Tools & Universal Parts
Here is an example:
https://www.rockauto.com/en/tools/ho...acuum+hose,230
so you find what you need, then you cut it to size.
VERY important is that you are aware of OD (outer diameter) and ID (inner diameter) for all hose stuff
This is how I fixed my leaks in the transmission and fuel lines, the parts were hundreds a piece, I just got some 25 foot hose and cut it myself as needed, saved a fortune.
Then make sure you get some quality clamps to hold it all together.
Here is an example:
Crushed
Jun 23, 2012 07:00 PM
worangejuice
Jul 20, 2011 03:38 PM
