My 98 Max : JIC Coilovers+fender rolling+G35C rims...now boosted
Old May 12, 2013 | 10:50 PM
  #81
carsnwomen91's Avatar
Waiting on that PM...
Same here... double teamed, bang bang!
Old May 13, 2013 | 03:21 AM
  #82
Leo_Koneval's Avatar
Oh man another tease!
LAWD HAVE MERCY!
Old May 13, 2013 | 10:53 PM
  #83
So this is where all the supercharger kits went LOL
Wasn't me. haha That last few SC kits I've bought came with Maximas attached to them. LOL
Patience young grasshoppa
Originally Posted by mista0406
If you haven't already you should get some 2005 murano center caps... they fit perfect as you can see in my sig Wiz... also I have 15mm in the rear and 5mm in the front on 235/40 all around
Hey, it's my twin! Thanks for the advice, will do. What brand spacers do you have? and are you happy with them?
LAWD HAVE MERCY!
Ok. ok. one more for now...
Old May 14, 2013 | 07:31 AM
  #84
Well..
You really gonna run that chitty filter?
Old May 14, 2013 | 08:03 AM
  #85
std aja de's Avatar
Pixell
oh man, i really want those s/c
Old May 14, 2013 | 09:47 AM
  #86
FastnFuriousMax's Avatar
Well..
filter looks fine to me, plenty of SA semi clean.
Old May 14, 2013 | 12:33 PM
  #87
mista0406's Avatar
I have Ichiba hubcentric wheel spacers... 15mm in the rear, with pressed-in studs on the spacers, and 5mm in the front, with no longer studs. I am extremely happy with them, lightweight and easy to install. I get no rub cruising as low as I am, only when I have more than just 1 extra person in the car with me lol. Hope this helps man.
Old May 14, 2013 | 12:48 PM
  #88
Are you referring to looks or performance?
Performance wise, that filter is more than enough based on my calculations for a 3.125 pulley. It's twice the size of the original pancake filter Stillen provided.
Thanks for the info mista0406, much appreciated!
OAN, my Max has been down for 3 months during this build. I just want to drive it for a while and make sure it runs smoothly before I start on phase II.
Old May 14, 2013 | 12:53 PM
  #89
Old May 14, 2013 | 01:52 PM
  #90
Amerikaner83's Avatar
clean up and color-match those rad. support brackets...
other than that...
Old May 14, 2013 | 02:13 PM
  #91
other than that...
yes sir, and the hood sensor bracket thingy. Powdercoating system is on the way...Now I gotta find me a cheap oven on CL...
Old May 14, 2013 | 03:39 PM
  #92
mista0406's Avatar
No problem man glad i could help.... By the way very nice Wiz I see you didn't shay away from the mevi haha, why not an 00vi?? I thought you wanted it different.
Old May 14, 2013 | 06:52 PM
  #93
cjandura's Avatar
Which system you get? Eastwood or craftsman? Be careful if you use a toaster oven on small parts it tends to burn the powder if its too close to the top coils
Old May 14, 2013 | 09:33 PM
  #94
Are you referring to looks or performance? Performance wise, that filter is more than enough based on my calculations for a 3.125 pulley. It's twice the size of the original pancake filter Stillen provided.
I just don't like K&Ns but what's the CFM of it?
Old May 15, 2013 | 07:19 AM
  #95
std aja de's Avatar
Pixell
Old May 16, 2013 | 01:33 PM
  #96
Did I hear you say you had plans to crack 400whp with this max? If so what are your plans to do so?
Old May 16, 2013 | 07:20 PM
  #97
Shift_Max's Avatar
Who produced that radiator?
Old May 19, 2013 | 01:06 PM
  #98
98nismomax's Avatar
How many maxima's do you have and are they all boosted?
Old May 19, 2013 | 04:10 PM
  #99
I am surprised how normal your air filter looks!
I was expecting to see a Nismo, gold-plated, diamond-cut carbon hyper-threaded air filter with the filtering element made from finely woven spider silk, Kevlar, and hair from the mane of a unicorn; all stitched together using the thread from the very fabric of time and space.
Just teasing lol
Old May 19, 2013 | 04:34 PM
  #100
mista0406's Avatar
hahaha^^^^^^^^^ This guy mane form a unicorn
Old May 30, 2013 | 08:08 PM
  #101
Eastwood
Not with this Max, but on the beast.
Griffin
Just teasing lol
^This guy!! Always says the funniest, wackiest stuff!!
Old May 30, 2013 | 09:07 PM
  #102
Besides the SC install, I did the following:
Rebuilt SC with new input/output/volute/casing seals and replaced impeller (old one had chipped tooth)
Painted SC mounting plate gunmetal (6 coats)
Z32 fuel filter
1 step colder NGK copper spark plugs
PCV valve
Cleaned TB and IACV
Earls -AN fittings and Aeroquip high pressure fuel lines
No wires anywhere! Hidden in conduit and electrical taped for an OEM-ish look. Relays hidden under fuse box.
Plus...
Vortech flush pulley retainer assembly
No wires!
Stillen battery tie down
Samco silicone radiator hoses with t-bolt clamps
old impeller with chipped tooth
inbeforechrisman287bugsmetosellittohim
Next up...paint/powdercoat the plates for the Stillen FSTB gunmetal, as well as the radiator hold down brackets and hood sensor bracket
Old Aug 25, 2015 | 01:01 PM
  #103
CarlW's Avatar
How low do these go?
Old Aug 25, 2015 | 01:10 PM
  #104
Fakie J Farkerton's Avatar
.5"-2.5"
Old Aug 25, 2015 | 08:03 PM
  #105
about as low as your Mom's panties everytime I come over....on the ground.
Old Aug 25, 2015 | 11:45 PM
  #106
max ride 41's Avatar
so, when are you going to clean underneath the hood, so dirty!!!
Old Aug 26, 2015 | 07:14 PM
  #107
CarlW's Avatar
Gee whiz that's pretty low
Old Aug 29, 2015 | 03:50 PM
  #108
I am serious though. You could get the Max 1inch off the ground if you wanted to.
Old Oct 5, 2020 | 08:15 PM
  #109
Leedon's Avatar
Wow
Sweet ride the sc is sweet
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
MichMaxFan
Sep 30, 2015 09:18 AM
