Solved the limp home thing but now...wtf?
Old Jul 18, 2002 | 07:36 PM
blackandwhite's Avatar
To them I'm like an idol
I replaced my MAF sensor, and my car came out of "limp home" mode, but after about 15 minutes of driving, it refused to accelerate. If I pushed the pedal hard, it would bog down, but if I accelerated slowly, it would sputter and slowly climb. Then all of a sudden, it cleared up.
Any suggestions? The only other thing I can notice that is wrong, is that the exhaust is very loud, that might just be loose bolts though. Maybe
Old Jul 18, 2002 | 09:10 PM
Dummy's Avatar
did you reset the ECU when you put on the MAF?
Old Jul 18, 2002 | 09:25 PM
No, but it was working
Should I try that?
Old Jul 18, 2002 | 09:59 PM
pearl93max's Avatar
how old is that fuel filter.....I still had the oroginal one on when I bought mine...like 135000 miles or so. It was doing the same thing...changed it out...ran like a champ afterwards.
Old Jul 18, 2002 | 10:34 PM
veejayes's Avatar
yea i was thinking along the lines of a fuel filter too...sometimes if you let you tank run almost empty, you pick up deposits in the bottom of the tank, thus clogging your filter...just a thought...
Old Jul 19, 2002 | 05:05 AM
I just changed it 3 weeks ago
But I'll try an additive. You still want the UDP? GEt in touch with mike he has it.
Old Jul 19, 2002 | 08:06 AM
Matt93SE's Avatar
STFU n00b!
don't use any additives.. they're VERY hard on the injectors.
for the price of a fuel filter, you may want to switch it out again and see what that does. also check your fuel pressure to make sure it's where it should be. if there's a clogged filter or the pupm is failing, your pressure won't be right (duh!).. I believe it's about 43psi at idle, but don't quote me on that. it's mentioned in the FSM.
Old Jul 19, 2002 | 08:46 AM
mykizism's Avatar
by additivies do you mean stuff like Fuel injector cleaner?
Old Jul 19, 2002 | 10:34 AM
More things I've noticed
Okay, the exhaust noise was a loose connection between the cat and the catback. It's fixed, but the hesitation is worse than before I changed the MAF sensor. Now when it does it, I can hardly get the car going at all. <1500 rpm and it bogs down. I think my throttle cable is loose too. I think the hesitation might also be a loose or faulty connector. It seems that the hesitation goes away when I get out and wiggle the MAFS connector.
But I am thinking that it is more than that because even with it unplugged (before I changed it), it just did the 'limp home' thing, now it's worse. Maybe the one I bought is bad too. WHo knows?
Right about now, I feel like the guy trying to plug holes in the damn with my fingers...
Are the VE and VG fuel pumps the same? are they both located in the same place? I have an FSM, but it's in Dallas still in the box. Can I get a tool from auto zone to check the fuel pressure?
Old Jul 19, 2002 | 10:48 AM
Taegost's Avatar
Re: More things I've noticed
Have you tried resetting the ECU like was mentioned previously?
Old Jul 19, 2002 | 06:43 PM
pearl93max's Avatar
yeah..I still want the UDP......accually I'm going to mike's in a few to get it put on!
DJLAX152
May 4, 2021 11:46 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Need help
23
Oct 2, 2015 08:56 AM
