Anyone else BLOWING THRU Wheel Bearings??
Old Aug 28, 2002 | 04:18 PM
My 4DSC
Today was my second trip to the dealership for this problem in the past 3 months.
My warranty is up in another 2000 miles.
Hope I don't have to change these everytime I change my oil.
This could get expensive once it's no longer under warranty.
Old Aug 28, 2002 | 06:10 PM
see5's Avatar
Had 5 Maximas and never a wheel bearing???
Old Aug 29, 2002 | 06:46 AM
Vadim's Avatar
Re: Anyone else BLOWING THRU Wheel Bearings??
front bearings or rear? if it's front, then I would check the ground cable coming from chassis to the enginge.
Old Aug 29, 2002 | 07:28 AM
TimW's Avatar
The silent but deadly Moderator
No, but you could have a bad rotor that you just dont feel. Certainly the vibration would kill it, especially if you've replaced the bearings more than once.
Old Aug 29, 2002 | 07:32 AM
njmaxseltd's Avatar
Re: Re: Anyone else BLOWING THRU Wheel Bearings??
What would a ground (Electrical) have to do with bearings failing? (Mechanical)
Your statement makes no sense.
Old Aug 29, 2002 | 07:48 AM
Vadim's Avatar
Re: Re: Re: Anyone else BLOWING THRU Wheel Bearings??
if you have a bad ground or no ground going to the engine, the current will try to pass thru things like axles and bearings to get from the chassis to the engine. Thus over a period of time it will ruin them. He might not have this problem, because this takes time, but a very simple thing to check on.
Old Aug 29, 2002 | 08:29 AM
Green 2kSE's Avatar
Re: Re: Re: Re: Anyone else BLOWING THRU Wheel Bearings??
That's just nonsense!
Old Aug 29, 2002 | 10:13 AM
koostermax's Avatar
Re: Re: Re: Re: Re: Anyone else BLOWING THRU Wheel Bearings??
my thoughts exactly.....
hypothetically speaking, if that's the case then the brakes would have fried, all the wheel bearings would have fried, the drive shafts, transmission, etc., etc..... heck your whole vehicle would be undrivable, since your keyhole, shifter, brake and gas pedal would be "electrically" locked.
Bottom line, an electrical shortage cannot affect a mechanical component such as a bearing (non-driven, free-floating)...
I don't like flaming people, but sometimes when common sense isn't used, you are gonna get it....
Old Aug 29, 2002 | 10:59 AM
TimW's Avatar
also, did you have aftermarket wheels that where the right offset? Did you get an alignment occasionally? 'cause that could also contribute
Old Aug 29, 2002 | 07:17 PM
My 4DSC
1st time it was for the front psgr wheel bearing...
2nd time it was for the rear bearing...
I have stock 2002 GLE's on the car...
And havent gotten an alignment yet, doesnt seem to need one...
I have 33.5k miles on the car...
....and i don't think its a bad ground.
Old Aug 29, 2002 | 09:33 PM
TimW's Avatar
I'm just thinking heat or vibration. I've heard of dragging brakes doing it.
Old Aug 29, 2002 | 09:40 PM
nismo2020's Avatar
Needs non-Maxima Friends
ive toasted both sides only once. i thought it was from burnouts but i stop doing that and the other side went too. just natural wear i think.
Old Aug 29, 2002 | 11:54 PM
acMAX's Avatar
My rear passenger side wheel bearing went to sh*t at 36K
So far so good since I got it replaced and I'm about 4K in.
Old Aug 30, 2002 | 05:37 AM
RussMaxManiac
Umm that is a LOAD OF CRAP. Please do not give false information on here again.
Old Aug 30, 2002 | 08:17 AM
TimW's Avatar
No, no people, its not a total load of crap. Its not applicable to our cars, but some large vechicles, like constuction equipment can have problems with grounding and bearings. Also can happen in aviation where static discharge and lightning strikes can spot weld a bearing race.
And since some tires are still steel belted radials, you can carry current to the ground, can happen with lighting or very high voltages, again with industrial equipment.. but I wouldnt think a max.
Old Sep 3, 2002 | 02:26 PM
bestnissanparts's Avatar
We are a large metro dealer and we are not seeing any patterns of this problem. Did the noise go away when they changed the last bearing? Did they change one side or both sides? Please e-mail me at todd@raybrandtnissan.net with the answers to these questions and I will give you more information.
Old Sep 3, 2002 | 02:33 PM
Driven EF9's Avatar
have you had an opportunity to look at the wheel bearings? was the grease dirty? How are the bearings, they look 'tore up'? Did it seize? What's happening?
how do you know it's the wheel bearings?
about the electrical problem blowing wheel bearings... it's probable, but VERY VERY unlikely. His ABS sensors would fry before the wheel bearing...
Old Sep 3, 2002 | 10:16 PM
MaxVQ's Avatar
Have you had any tranny work done on the car? When the tranny is out, the dealer MUST install and torque the CV shaft BEFORE they roll it anywhere. If not, the bearing will develop a small PIT, and get very loud over time.
goto www.motorvate.ca and click on Steering & Suspension, have a look at my wheel bearing.
Take Care,
bbsitum
Sep 6, 2019 07:31 PM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
