New Springs / Drawbacks to Lowering 1990 Maxima ?
Old Dec 26, 2000 | 09:47 PM
garfo
I have a 1990, 3rd Gen Maxima, it has the sonar suspension as I think all came with. I am wondering if this will be affected by the replacement of the springs with some sport / racing that will drop it 2-3 inches or less if the shocks won't be able to handle it. Thanks, I'm relying on you guys, cause you are the ones that know my car best! Thanks for the help and I hope you had a happy holiday whatever you celebrated! Thanks again.
-Garrick
Old Dec 26, 2000 | 10:06 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Well..............
If you lower that car 2-3 inches you'll be scraping every speedbump and curb on the road as well as dangerous debris!! also I'm not real sure on the Sonar Suspension shock realiability, but I'm pretty sure if OEMs haven't been replaced and you're still riding on the 10 year old factory equipment(which is hard to believe anyways) you'll have some probs with an excessive drop(IMO, 1.75 or lower!) I'd see what kind of replacement performance shocks your car can use (if not the regular Tokicos, etc.) first before you get springs that low!! by the way the lowest avilable right now is 2" drop Sprint springs unless you get a "custom cut"!! My dads first gen Max had Sonar II and it worked up until we sold the car in '94, but I didn't really get to analyze the system enough to fully understand it past the adjustable stiffness. hope this helps
Old Dec 26, 2000 | 10:19 PM
davis449
If you want my advice, get rid of the Sonar II suspension. I've heard they cost $1000 or more to replace when they go out. So if you want my advice, pay the $400 or $500 and get Tokicos or Konis or something. Just have them replace the whole suspension. The people I go to said it's a real ***** to deal with and that modding it with springs or whatever is a bad idea.
Old Dec 26, 2000 | 11:14 PM
Weasel's Avatar
I'm a semi-ignorant 4th gen guy... what is Sonar suspension?
Old Dec 26, 2000 | 11:21 PM
Foo90SE
it had a sensor and electronically adjustable shocks so it could adjust to road conditions. Similar to ford's system on their lincoln continentals only they used air to do it. glad mine dosnt have it
dank4us
34
Jun 10, 2024 03:45 AM
CRizz
41
Jun 7, 2021 05:42 AM
twotonezed
Aug 16, 2015 08:10 PM
soon2ownmax
Aug 13, 2015 02:19 PM
