KOP HID's
Old Nov 29, 2002 | 07:18 PM
juice's Avatar
KOP HID's
A friend of mine has become a distributor for KOP HID Lighting Technologies. All there products are top of the line and are manufactured from German parts. The are made of the same material as the Phillips HID lighting systems. All products come with a manufactures warranty. Also as a note the higher color temperature bulbs are not the tinted glass like some of the other manufacturers are using. The colors are achieved by using precise gas mixtures. Products available right now
Pics to bulb comparisons
For the 2K2 and up models who want to change just the bulbs.
-6000K D2R - Violet $200 a pair
-7000K D2R - Light Blue $200 a pair
-8000K D2R - Blue $220 a pair
Shipping is $7
These bulbs are a direct replacement for the OEM bulbs
Currently only H3 kits are available. Kits include all necessary hardware including bulbs, ignitors, starters and ballasts. Kits are direct fit into the OEM foglights and tap into the old factory wiring(for on/off)
-6000K - Violet $450
-7000K - Light Blue $450
-8000K - Blue $475
Shipping is $10
9004 and H4 kits will be available in 2-3 weeks and these will be hi/lo beam direct plug-n-play kits. Please e-mail me for all questions and on how to order. Thanks
Old Nov 29, 2002 | 09:17 PM
2M0A0X2's Avatar
do u only have to change the bulb to get more blue of the 6000k?
Old Nov 30, 2002 | 12:57 AM
ThurzNite's Avatar
what do you mean by hi/lo beam plug and play? do you mean it uses a diode to keep the hid on when you flick to hi?
Jae
Old Nov 30, 2002 | 01:27 AM
juice's Avatar
HID's
Jae
2M0A0X2 - If you have a 2k2 or higher, yes all you have to change is the bulbs to get more blue or purple, see link above to pics.
ThurzNite - Actually it uses a relay, and when hi beams are engaged it changes the angle of the bulb to a higher beam pattern.
Old Dec 2, 2002 | 06:58 AM
K Pazzo 6's Avatar
Re: KOP HID's
Shipping is $7
-8000K - Blue $475
Shipping is $10
wow ...now i gotta save up for these bulbs
Old Dec 2, 2002 | 07:04 AM
funnylittlman's Avatar
I'm interested in the low/high hopefully. Price?
Old Dec 2, 2002 | 10:37 AM
juice's Avatar
Hi/lo Beam
Price depends on the color kit desired the higher color temp (ie 8000k) are more expensive. They run from $450 to $500 per kit
Old Dec 2, 2002 | 01:25 PM
Juice,
Just to make sure, the bulb itself doesn't move, but it is similar to a dual filament bulb?
Old Dec 2, 2002 | 01:46 PM
juice's Avatar
Hi/Lo Bulbs
Juice,
Old Dec 3, 2002 | 05:54 AM
Somethin Funny?
Old Dec 3, 2002 | 10:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
Somethin Funny?
yes...because a HID bulb does NOT act like a normal bulb. once it's ignited and lit..it stays lit. unless there's another bulb "hybrid" then the HID bulb/capsule will stay lit regardless of high or low beam.
the way they control the high beam and low beam "generally" is they have a relay to control a shield on a H4 bulb. but it does not act like a regular bulb...so juice is incorrect on his info.
Old Dec 3, 2002 | 12:58 PM
Oh ok. I got ya!
That's what I was wondering, b/c all the "dual's" that i've seen have had a servo (manually moved) or had another bulb on it (the dual xenon that Bimmers use now). My bad
Old Dec 3, 2002 | 01:14 PM
juice's Avatar
Hi/Lo
The above description is correct for one type of Hi/Lo kit that is available. It uses a relay to allow the bulb to stay on when the Hi beams are engaged. These kits are currently in stock.
The second type of Hi/Lo kit which I attempted to describe works with a solenoid that is able to slide the bulb itself back and forth, hence changing the angle in which the light is output. I apologize for my incorrect information in my above post. However thes kits will not be ready for a short while.
Again my apologies.
Old Dec 3, 2002 | 01:30 PM
Juice,
I have heard nothing bud bad things about the Solenoid ones. They crap out fast.
What's your opinion?
Old Dec 3, 2002 | 01:49 PM
juice's Avatar
Juice,
Thats exactly why we dont sell the current available ones yet because there are still bugs in the systems. We are looking into other developers in Germany and currently testing those systems. I really can't say when they will be ready because it depends on how long it takes find and correctly functioning product.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
