Good God
Old Nov 29, 2002 | 09:00 PM
Nismomaxt's Avatar
Good God
I just spent my whole day removing cylinder heads for exhaust stud replacement. Let me just say...this is a major operation. I have pictures Ill post when Im done. I just hope my car runs when Im done. Turns out I had busted studs in both front and back heads. Ive got both JWT cams in place and tomorrow Ill be puting my engine back together. Wish me luck.
Dano
Old Nov 29, 2002 | 11:39 PM
Kevincleff's Avatar
Re: Good God
Good Luck
Old Nov 30, 2002 | 07:38 AM
D-sta's Avatar
Re: Re: Good God
Originally posted by Kevincleff
Good Luck
Good luck, I heard that's a big a$$ job that I don't have to do yet but I suspect that one day it will happen.
Old Nov 30, 2002 | 08:11 AM
RosenKen's Avatar
The worst part of the job is the moment before you crank it back up Good luck, I've done this before! Remember to tighten down all your coolant hoses
Old Nov 30, 2002 | 09:56 AM
Nismomaxt's Avatar
Im replacing most of them, so they should all get tightened....should. Thanks for the support.
Dano
Old Dec 1, 2002 | 12:22 AM
Aphrodisiac's Avatar
Re: Good God
Dano
Wish I knew how to do that
Old Dec 1, 2002 | 07:59 AM
Taegost's Avatar
Re: Re: Good God
Hehe... In a way yes, in a way no... It's a PITA... I just replaced all 12 of mine because I had 7 snapped, the only mechanic who would even look at it was our family mechanic, took them all day...
$548 in labor, @ $60/hr
Old Dec 1, 2002 | 11:24 AM
Nismomaxt's Avatar
Re: Re: Good God
To be honest, I really didnt know how to do it either. I have a chiltons and the factory service manual so between the two I have all the info I need. Should be done today. By the end of this job Ill have installed the JWT cams, underdrive pulley, warpspeed y-pipe, and cattman CAI. Cant wait!
Old Dec 1, 2002 | 11:32 AM
RosenKen's Avatar
Re: Re: Re: Good God
Heh, well you *might* feel a difference
They did give you instructions on how to properly break-in new cams right?
Old Dec 1, 2002 | 12:49 PM
Nismomaxt's Avatar
Re: Re: Re: Re: Good God
Um...NO! What is the proper way? The cams came with nothing but..well, cams.
Old Dec 1, 2002 | 12:52 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Re: Re: Re: Re: Good God
I've heard a 400mi break-in is necessary(no revving over 3.5-4k) for "new" cams....not too sure about regrids, but I'd assume the same. I assume you installed new lifters as well??
Old Dec 1, 2002 | 02:11 PM
RosenKen's Avatar
Hmm might want to research a little on the net or call JWT to ask. Usually to introduce the cams to the lifters and bearing journals you need to start the car, quick check for leaks and normal operation, then rev the car up to 3000rpm and leave it there for about 5 minutes or so. This is vague memories of what I heard a long time ago. Call JWT
Old Dec 1, 2002 | 02:56 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: Re: Re: Re: Good God
thats how I used to break in cams on v8s but not sure if it would be different on a ohc import.
I just went through this on a 92 gxe...I had to get the heads re built though because all the valves were bent.
be sure to clean everything up while you have it off.
Old Dec 1, 2002 | 03:04 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: Re: Re: Re: Re: Good God
oh and I almost forgot...if you havent gotten the broken studs out yet be sure to soak them several times in wd40 and let it sit over night. I did this and they came out so easy it supprised me. I had 6 broken studs but replaced them all.
Good luck.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maximan190
Dec 16, 2015 06:01 AM
MaxLife17
Sep 8, 2015 02:36 PM
