all those with automagic's
Old Dec 10, 2002 | 08:01 PM
nesquiknate's Avatar
when driving around city streets do you have o/d on or off? i know this is a stupid question but i just wanted to know
Old Dec 10, 2002 | 08:06 PM
XXXL Cracker's Avatar
Re: all those with automagic's
On and yes it is....
Old Dec 10, 2002 | 08:13 PM
clee130's Avatar
I drove with it off if I was in stop and go traffic.
If it was traffic that opened up a little bit and I could get above 30, I turned it on.
Old Dec 10, 2002 | 09:06 PM
ptatohed's Avatar
Licensed to Spell
:o)
Why?
Old Dec 10, 2002 | 09:53 PM
Nismo's Avatar
OD is always on since I have to go above 40mph all the time. unless im in stop and go then its off
Old Dec 11, 2002 | 12:06 AM
99maximagxe's Avatar
I drive in stop and go traffic all the time (Cali) I dont turn o/d off cuz i heard it consumes more gas so i leave it on. Do you feel any difference in terms of mileage? with o/d on and w/ it off
Old Dec 11, 2002 | 12:10 AM
DerekJ212's Avatar
Of course it would take more gas. Its simple, look at your RPMs with it on, and watch them increase with it off. More RPMs, more gas...
Old Dec 11, 2002 | 12:22 AM
Max Noob's Avatar
od is basically a button telling the car its allowed to go into 4th gear right??.. if you leave it off you car will stay in 3rd...3rd gear goign fast = higher rpm..= more burnt gas..
Old Dec 11, 2002 | 12:46 AM
ptatohed's Avatar
Licensed to Spell
:o)
Which is it? always or not? lol.
Why do you guys feel you need to turn it off when you are at low speeds? That makes no sense.
Old Dec 11, 2002 | 12:52 AM
GoldenGlory
since i got my VB mod done @ jeff;s
i throw in to 2 and drive on ...
tranny cooler kicks a$$ !!
VB mod and traffic do not combine well ...with stop n go traffic
Old Dec 11, 2002 | 01:03 AM
Dev's Avatar
Dev
Re: :o)
i drive stick but ill post anyways.
doing this in stop and go traffic may waste a bit more gas, but nothing significant unless going at higher speeds.
the reason to turn off o/d is to stop the transmission for shifting back and forth between 3rd and 4th gear in stop and go traffic.
this is better on the transmission (less shifting), and eats a bit more gas.
Old Dec 11, 2002 | 06:39 AM
clee130's Avatar
Re: Re: :o)
Yep, leaving O/D off in stop and go traffic makes the transmission less likly to "hunt for gears".
It's really a personally preference. Some people leave it on all the time, some people turn it on and off. The manufacturer put O/D there for a reason, might as well use it.
Old Dec 11, 2002 | 07:47 AM
JPMax's Avatar
What's next!?..
Yes, sometimes when I'm in slow traffic I'll turn off o/d too. The car drives more smoothly since it doesn't shift gears as much.
Old Dec 11, 2002 | 09:44 AM
Lime's Avatar
overdrive merely tells the car whether or not it can go into 4th gear. The 3rd gear RPM's will be different as a result.
Mine is almost always on. If there is a lot of snow, sometimes I turn it off to make sure I stay in a certain RPM level.
Old Dec 11, 2002 | 10:46 AM
MarkD's Avatar
Mine is always on.
Old Dec 11, 2002 | 12:40 PM
mrmaxima97's Avatar
Originally posted by MarkD
Mine is always on.
I usually drive with mine on, except on some roads where my speed drops below 25 and goes as high as 35 (back and forth). Everywhere else I leave it on.
Gotta love 'automagic'.
Old Dec 11, 2002 | 01:00 PM
Joeycurl's Avatar
I leave mine on, but when I'm in traffic I turn it off.
Old Dec 11, 2002 | 10:54 PM
(_8*(l)Homer's Avatar
You know... I thought about it once, but didn't do it.
Old Dec 11, 2002 | 11:00 PM
Nismo's Avatar
Re: :o)
99% of the time its always on. on some occasions when I have to drive in stop and go Lower speeds because at around 38mph it will shift to 4th so why let it shift to 4th when your going to have to slow down for traffic a second after it shifts?
Old Dec 12, 2002 | 08:58 AM
Neuhowse's Avatar
LOL! Dumb moderator.
Old Dec 12, 2002 | 12:23 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
My O/D is always on even w/ the high amounts of stop-n-go driving here in metro Detroit
gettin time for a tranny flush soon
Old Dec 12, 2002 | 12:36 PM
jbreit's Avatar
with OD on, the torque converter will "lock up"...meaning it will cease being a fluid coupling and become rigid. this will reduce the heat the torque converter has to deal with and increase your car's efficiency....but if its going in and out of lock up (like in stop and go traffic that gets over 35-40mph), that wears on it. Excessive heat is the biggest enemy of your transmission and torque converter.
Old Dec 12, 2002 | 12:49 PM
Stephen Max's Avatar
Back when my car was an automatic (I just love saying that, I think I'll say it again) Back when my car was an automatic, I kept the OD off in town, mainly so if I had to step on it there wouldn't be any wasted time unlocking the torque convertor and downshifting into third.
Old Dec 12, 2002 | 03:02 PM
njmaxseltd's Avatar
I turn OD/OFF when I'm in city traffic. It keeps the tranny in 3rd gear which makes the car more responsive. I don't want to be in 4th gear @30 MPH trying to get in front of a cab.
There's also less shifting that the tranny has to do which I feel keeps wear-n-tare down. Less shifting the tranny has to do means the longer it's gonna live.
Old Dec 12, 2002 | 03:45 PM
NATE98GLE's Avatar
Re: Re: all those with automagic's
Why doesn't the VB mod and traffic combine well with stop n go traffic?
Old Dec 12, 2002 | 04:00 PM
iregula's Avatar
just leave it on
Old Dec 12, 2002 | 04:30 PM
Asian_N02's Avatar
i switch mine off in stop n go traffic. my car shifts much less with it off below 30 mph. otherwise i leave it on...hope all of our replies are helping you decide what to do...
Old Dec 12, 2002 | 06:19 PM
Romeo's Avatar
Re: Re: Re: all those with automagic's
i'm guessing because the "jerkyness" of the shifts???
Old Dec 12, 2002 | 06:57 PM
MaxWolf's Avatar
We have an O/D button?
Just kiddin... just gives you an "extra" gear for highway traveling....High RPM's = harder on the engine
Old Dec 12, 2002 | 08:23 PM
thanks for all the replies on this. it made me decide to leave iton b/c i onl drive back and forth to school, which doesnt deal with much traffic
Old Dec 12, 2002 | 09:18 PM
Cumalot's Avatar
I turn OD on/off on the street and on the highway. Does it really make any difference? Maybe, maybe not. Since I have an automatic and not able to shift, I got nothing else to do so why not turn OD on/off.
KniGhtRydeR
Nov 13, 2001 09:21 PM
1Phat Max
Nov 11, 2001 09:42 PM
stevechen
Oct 22, 2001 02:42 PM
Pat DiPersia
37
Oct 18, 2001 06:28 PM
yongjun
39
Oct 9, 2001 10:31 AM
