What is the latest and greatest sparkplugs to get now?
I know in the LS1s we take out the stock platinum plugs as fast as possible and replace them with copper NGKs. I am not entirely sold on platinum plugs. What do you think NGK coppers?
Oh by the way how big of a job is it on the Maxima?
Originally posted by emax95
Look up one post
Look up one post
How about my second question?
By the way I was just drooling on your website when you just replied. VERY nice Max!
OK I did question answered.
Question #2. That depends on how mechanicly inclined you are. The front 3 plugs are real easy to swap. The rear 3 are another story. At the very least the intake manifold runner needs to be removed. In all honesty it's easier to just remove the whole intake manifold. I expect it to take me about 45 minutes to do the plugs.
Iridium?
Copper is suppose to be better because it has less resistance (electricity can flow thru it better.) Platinum have more resistance but it last much longer, so it is the spark plug of choice for cars.....
Iridium is suppose to be less resistance than copper AND tougher than platinum.
So the best of both worlds?
Comments??
Comments??
People seem to think copper plugs perform better. There real cheap so I am going to try switching to them once my car is repaired(MAF fouled my plugs).
how do you know that the the plugs are bad due to the MAF?? my MAF went out on me a month or so ago, and i had it replaced with the newer MAF. i want to know if i have to replace mine also, without having to pull them out for inspection.
Re: What is the latest and greatest sparkplugs to get now?
Fifty million years ago, an asteroid composed almost entirely of the precious metal Iridium (Ir-77) struck the earth creating the Gulf of Mexico. From this catastrophe came a metal with properties ideal for spark plug construction. Using this element, DENSO has evolved spark plug design to a new level. Using Iridium, which is 6x harder & 8x stronger than platinum, the tip can be shrunk to only 0.4mm. This means the voltage requirements are decreased while firing performance is greatly improved..02
Originally posted by victor
emax,
emax,
Re: Iridium?
Comments??
Comments??
From what I have read, both Platinuma and Iridum last a LONG time; Iridium lasts the longest. I also have read that Copper may be a good option for NON-N/A cars.
I went with platinum on my 2000 and I did not have much trouble. It just took a while to finish. Is the install on the 2K2+ different than on 2K and 2K1's ?
Is the Iridium the plug to get then? Denso?
http://www.rvmracing.com is listing them for sale ($68.99/set) but I am not sure if the part number (IK16-5303) is correct since they listed them for both 2k-2k2? FYI, NGK has difference part number for 2k & 2k2 according to Courtesy Nissan website.
Tha'-Max
Aug 30, 2015 01:14 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
