Tweeter hiss
Tweeter hiss
Hey all,
I just installed 2 sets of component speakers (front and rear) and am very happy with the results. However, during quiet parts in a song with the volume up high I can hear a "hiss" coming from the now amplified tweeters (located in the pillars front and rear). I remember the days of the Dolby "B" circuit reduction that could eliminate such a hiss from a tape, but what can I do for my CD?
I don't know if I'm better off turning up the gain on the amps and using a lower volume on the stereo or vice-versa. I don't know if an amp or a head unit has more noise. Oh, just to clarify this isn't engine / alternator noise I'm talking about...luckily I did the install right!
Any ideas would be appreciated!
Re: Tweeter hiss
Originally posted by spta97
Hey all,
Hey all,
I don't think that you have the same problem, though. If I were you, I would readjust the amplifier gains, they may be set too high. Turn the amplifier gains to the lowest setting, and then run your headunit up to the point that you think you will never go any higher. Leave that setting alone. Now slowly turn up your gain on the amplifier until you start to hear the hiss or any distortion. This should reduce if not elminiate your problem.
Re: Re: Tweeter hiss
Originally posted by C-Dawg
Are you using a crossover or equalizer? I had a similar experience a few years ago.
Thanks.
Thanks.
95naSTA
Sep 21, 2015 06:50 PM
ericdwong
Jan 26, 2001 05:51 AM
