Warped Rotors....??
Warped Rotors....??
my rotors are warped...but sometimes when i brake, the steering wheel wont vibrate...everything seems normal...but than other times it vibrates like crazy when I brake...
does this happen to anyone else...
it vibrates most of the time when i brake..
Re: Warped Rotors....??
Originally posted by krazyd
I need the TSB for my 2k1 Warped Rotors. I'm bringing in the car and want to have it incase they give me any problems.
Make sure you get some pads too! Whenever u replace rotors, u need a new set of pads so they wont warp again.
My friend GXE-r who lives close to me, recieved rotors and pads for free under 36k protection wntty.
they will cut them
SoloMaxima,
I just took my 2000 GLE in for this problem. I had it for a while, but finally got there at around 33K miles.
Read the TSB closely - all it does it tell the service people how to cut the rotors.
You're going to have to fight a little harder to get a replacement.
First words out of the Service Advisor's mouth were " no brake inspection is covered under warranty - this will be at least $69.95" - I told him just look at them and tell the technician there is a TSB - I had the copy, but never showed it.
They called me later and said it would be done under warranty. I asked about replacements - they said no way.
Unless you have a super, service friendly dealer - you can forget replacements (unless this is something you've been there for in the past).
Just my experience
Just my experience
Re: they will cut them
Originally posted by simon tx
SoloMaxima,
Just my experience
SoloMaxima,
Just my experience
Re: Re: they will cut them
I had warped rotors on my 2k3 (no TSB) with 2100 miles. They cut my rotors (all 4) and sent me on my way. I argued ahead of time to get new rotors and pads but both the dealer and NNA told me no. It pi^sses me off because now my rotors have already been cut once therefore taking life away from them.
Re: Re: Re: they will cut them
and demand NEW
HELP!!
I just took my car into service yesterday, it was currently 36579, i planned on an oil change and fix brake bulb, but he called me later and told me i had to have my brakes replaced and rotors resurfaced. is this the same issue as you people have mentioned?? if so am i covered under any warranty due to tsb? can i get reimbursed?
thanks in advance
thanks in advance
Re: HELP!!
thanks in advance
thanks in advance
My dealer cut the rotors (fronts only...the rears never warped) the first time I took it in (12k miles) When i brought it back at 20k, they replaced the rotors. Both times were covered by warranty.
Two weeks ago, I took it back again with warped rotors. Unfortunately, at 50k miles, it wasn't covered. Dealer claimed they'd never had problems with Maxima brakes before. Uh huh...yeah.
Re: Re: HELP!!
Originally posted by Igor911
I hope u didnt pay for all that
Re: Re: Re: HELP!!
Originally posted by CCS2k1Max
Save the receipts (credit card and statement, as you should w/ all records) and if a TSB comes out, demand reimbursement from NNA. Basically you're the guinea pig, er data, they are collecting...
Igor, he did pay for that, but that's iffy since he's over 36K.
Re: Re: HELP!!
Actually yeah i did, heres what was done.
The brake pads, resurface rotors, replace fan belt (cracked), replace rear brake bulb, oil change, and usual fluids and odds and ends.
total: $420.95
Re: Re: Re: HELP!!
total: $420.95
total: $420.95
Re: Re: Re: Re: Re: HELP!!
No!!, just the f'in front!!!!
. Thats outrageous right??
Sounds a little steep to me. That is why once the warranty is out, the dealer will never see my car again.
Re: Re: Re: HELP!!
total: $420.95
total: $420.95
What do you mean by cracked fan belt? Max's have an electric motor that turns the fan(s). I think the dealer is pulling your leg as they usually do.
Re: Re: Re: Re: they will cut them
Next time u feel the SLIGHTEST judder, take that SH!IYAT back
and demand NEW
and demand NEW
) so I didn't notice it although it was probably there from the start.Luckilly, I have all my files in a big folder that I will keep until I sell the car.
raffivegas
Aug 23, 2015 09:54 PM
RealityCheck
Aug 5, 2015 06:18 AM
MrBurner
Apr 4, 2001 07:38 AM
DFWmax
Mar 21, 2001 03:00 PM
SWEETSOUND2001
Mar 1, 2001 12:52 PM
nice..
