bose subwoofer disconnect
Old Jan 18, 2003 | 02:52 PM
reggie's Avatar
I need to disconnect the stock bose subwoofer beacause i have a jl subwoofer in the trunk. the bose subwoofer rattles alot because of the bass the jl kicks. what wire or wires will i have to disconnect to take out the bose subwoofer without disconnecting the rest of the speakers. reply only if you have done this mod. to your car. thank you.
Old Jan 18, 2003 | 04:00 PM
studman's Avatar
Attached to the sub on the passenger's side is a brown (or grey) connector with 4 wires. You can unplug the sub there. The rest of the system will work fine without it, as that's what I did when I installed my subs. The factory harness wiring can stay attached to the car, and the sub will come out with no problem. However, remember that you have to remove the grille inside the cabin to remove the sub. I've also seen some years where you have to remove the back seat and the rear deck lid to get to the screws. I didn't remove the sub (just unplugged it) so I can't tell you if you'll have to remove the seat or not. Good luck.
Old Jan 18, 2003 | 07:13 PM
victor's Avatar
just pop the plastic bose grill on the rear deck, and you'll have access to the bolts holding the sub in.
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
maxima297
Sep 30, 2015 03:32 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
