keyless entry stopped working...
hmm....the only cases I've seen where mine locked up and stopped working is when I pressed random buttons that did nothing for a while. Then it automatically freezes until I manually unlock my car.
I'm not sure if this will help, but if you can get your pad working again, the code to set your unlock code is underneath your dash. Look on the left wall next to the underside of the glove compartment on the Passenger side. There should be a sticker with 3 sets of numbers on it. It's the bottom one of the 3. Copy this number down and ignore that letter before all the numbers.
To set the code, press 'ST'
Then press the code you copied.
It'll make a long beep noise, so input the new code you want.
It has to be 7 digits long.
Now test it.
Now test it.
i lost my keyless entry a while back also...since our cars are "older" seals tend to not work as well...so if you live somewhere where it gets cold at night, or snows, or rains a lot...water can get in there and mess everything up!
Apr 16, 2020 05:15 AM
maxima297
Sep 30, 2015 03:32 PM
