Clutch Fluid Leakage
A few weeks ago I posted a thread about the clutch petal staying on the floor, and the clutch master cylinder being bone dry. From everyone's directions and the help of a Haynes manual, I was able to pump new fluid through the lines and burp the air out, and the clutch petal felt better than it ever did.
Except now there is major leakage somewhere. Every 2-3 days I will find the master cylinder near dry. I don't know too much about clutches or how the hydraulic system works, or where to check for leaks. During the day I will look a little closer to see if I can find brake fluid leaking, but in the meantime, does anyone have any ideas or suggestions?
Re: Clutch Fluid Leakage
Basically, you have a master cylinder, mounted on the firewall of the car. When you press the clutch pedal in, a small rod, or plunger, pressed into the master cylinder, forcing fluid into the high-pressure hydraulic line that delivers the fluid to slave cylinder, mounted on the transaxle. All of your hydraulics are contained in these three pieces. So, if you're leaking fluid for the clutch, you need to check the master cylinder, check the joint between the cylinder and the line, for leaks, also. Then, trace all the way down, to the slave cylinder, and look for evidence of leaks there.
For replacement or repair, these are rough averages I found from the internet:
Complete replacemant of all thre parts : approx. $73, + s&h and/or tax.
Rebuild or repair, with new hose : approx. $28, + s&h and/or tax.
I had a problem like that before, remember? Funny thing is, the problem just went "away". I know things just don't go "away", so I checked it out.....
It just went "away". I couldn't find squat!
Originally posted by blackmaxima88
I can't be precise, but I think it's leaking from the release cylinder. what now?
S
If it's from the seals, you'll want to either rebuild or replace the cylinder. If you have ever rebuilt a drom brake cylinder, this is very similar.
The rebuild option is tons cheaper, but not for everyone.
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
