More boost news with leak fixed
Old Feb 21, 2003 | 09:52 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
With the leak fixed and the "gain rate" increased on the boost controller, I was able to hit 3.6 psi at 3067 (results taken from Blitz BC and A'PEXi S-AFC... yes, AFC not RSM) in 5th gear.
I can say, with confidence, that 2500 to 4000 is stronger than the SC EVER was in that RPM range. I will show proof of this when the car gets tuned on the dyno, but right now it is running very rich. I may make slight adjustments to the fuel this weekend, but no major tweeks will be done.
The car was not brought up to redline with the new changes so I don't know what peak boost is, but I did notice 4.5 psi on my way to work.
Old Feb 21, 2003 | 10:21 AM
Chunger's Avatar
My other car is a Hybrid
Wasn't tuning the S/C MUCH EASIER than with this turbo
Oh well... the potential is much higher with the turbo (as is the consequences)... tread lightly...
Old Feb 21, 2003 | 01:31 PM
UMD_MaxSE's Avatar
Got Bent?
just curious... what type of fuel system are you using? Did you go with the cartech FMU + Walbro or are you still using the vortech FMU + Walbro...
Old Feb 21, 2003 | 01:35 PM
Y2KevSE's Avatar
Yes, much easier to tune the SC because it was only the AFC and Vortech FMU.
Cartech FMU + Walbro. I need to get an in-cabin FPG.
Old Feb 21, 2003 | 01:39 PM
UMD_MaxSE's Avatar
Got Bent?
hehehe... turn the screw on the FMU and you won't run rich anymore
**BOOM**
j/k
Old Feb 21, 2003 | 02:07 PM
[maxi-overdose]'s Avatar
1 more day...1 more day.
I am going to exchange those vacuum tubes to the right size.
Old Feb 21, 2003 | 06:35 PM
chinaonnitrous1's Avatar
Re: More boost news with leak fixed
..i hit 2400 rpm on the way to work..couldn't go any higher either hahahhahah
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
pears
Sep 18, 2015 05:25 AM
seesole
Sep 14, 2015 12:38 PM
