More boost news with leak fixed
With the leak fixed and the "gain rate" increased on the boost controller, I was able to hit 3.6 psi at 3067 (results taken from Blitz BC and A'PEXi S-AFC... yes, AFC not RSM) in 5th gear.
I can say, with confidence, that 2500 to 4000 is stronger than the SC EVER was in that RPM range. I will show proof of this when the car gets tuned on the dyno, but right now it is running very rich.
I may make slight adjustments to the fuel this weekend, but no major tweeks will be done.
The car was not brought up to redline with the new changes so I don't know what peak boost is, but I did notice 4.5 psi on my way to work.
I may make slight adjustments to the fuel this weekend, but no major tweeks will be done.The car was not brought up to redline with the new changes so I don't know what peak boost is, but I did notice 4.5 psi on my way to work.
Originally posted by Chunger
Wasn't tuning the S/C MUCH EASIER than with this turbo
Oh well... the potential is much higher with the turbo (as is the consequences)... tread lightly...
Originally posted by UMD_MaxSE
just curious... what type of fuel system are you using? Did you go with the cartech FMU + Walbro or are you still using the vortech FMU + Walbro...
Re: More boost news with leak fixed
..i hit 2400 rpm on the way to work..couldn't go any higher either
hahahhahah
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
pears
Sep 18, 2015 05:25 AM
