those with IS300/roof mount antennas
How exactly is it mounted? What type of hardware is holdign it down? I know you drill a hole but what exactly is the process of the install? and also how does the wiring from the stock antenna go to the roof mount? easy to do? or does it require me taking off the whole headliner and all?
Re: those with IS300/roof mount antennas
I simply disconnected my stock antenna, and this one works just fine. I believe the antenna comes with a universal clip that you can plug into the back of the headunit or it just plugs in, I know I didn't need anything else but what came with it.
Don't take off the headliner, there are 3 clips along the back and 2 on the sides you can pull off and just pull it down a little bit. A word to the wise, run the wires as close to the middle of the headliner as possible or you won't be able to get it to clip back in place and it will rattle (if you have stereo).
Good luck.. just be careful drilling, that's the hard part.
Jason Sadler
Originally posted by 95emeraldgxe
the antenna on the s2000's look much better, they are a bit thicker and shorter - thats what most of the vwvortex.com members do on their jettas
Unclejunebug
Apr 2, 2016 05:42 AM
