what purpose does this serve?
Old Apr 22, 2003 | 06:08 PM
guitarn247's Avatar
reseting the ECU, what purpose does it serve?
Old Apr 22, 2003 | 06:12 PM
Maximax2's Avatar
Re: what purpose does this serve?
The ECU in your car "learns" your driving habits, and adjusts itself accordingly. During break-in, for example, you drive relatively slowly - the ECU gets used to driving most efficiently at low throttle positions, slow speeds, etc.
Long story short, when the ECU is reset you can start from a clean slate and have it adapt itself to more aggressive driving. Note that this isn't necessary, as it will eventually learn this behavior and adapt over time, it'll just take longer.
Also, if you install some mods (Y-pipe, CAI), I've heard it's a good idea to reset the ECU so it learns its new restrictions (or lack thereof).
Old Apr 22, 2003 | 06:13 PM
guitarn247's Avatar
ah....thank you got it now
Old Apr 22, 2003 | 06:19 PM
Maxman2000's Avatar
Ok just one more time (your gonna be ****ed of probobly about this) How do you reset the computer.
Old Apr 22, 2003 | 06:32 PM
Maximax2's Avatar
Okay, here's how you do it:
Stand in front of your car with the hood open
Kneel down and bow to the engine, while chanting "gimme more, baby; gimme more, baby"
Then install an NO2 bottle and kit
Simple, and you'll notice the difference immediately.
Okay, I'm bored. Anyway, the theory on the .org had always been that 5th gen ECU's weren't resettable by disconnecting the battery overnight (other cars can do this). Then yesterday I saw a post about doing that, so... dunno.
But the dealer can do it with their ECU system, which they would probably do for something like $35. And you could have them advance your timing while you're at it
Old Apr 22, 2003 | 06:37 PM
Maxman2000's Avatar
Hey Miximax2, what's your timing set at?? I'm thinking of doin 17 degrees advanced.
Old Apr 22, 2003 | 06:46 PM
Maximax2's Avatar
Well - the service manager said they were going to do two degrees (17), the tech and the receipt said they did one (16). So don't actually know - but more has to be better, right?
According to some other posts, up to 17 is still okay for warranty, but you might ask your dealer for confirmation.
Old Apr 22, 2003 | 07:59 PM
studman's Avatar
Here's how to reset the ECU:
http://maxima.theowensfamily.com/reset-ecm.jpg
Old Sep 6, 2003 | 08:56 PM
JodyBerry's Avatar
Originally Posted by studman
I saw your info on how to reset the ECU. Does this reset it completely so that the system has to re-learn, or does it just reset the trouble codes?
Thanks,
Bill
Old Sep 6, 2003 | 10:10 PM
ÀÜSSÎË's Avatar
G'day,
Thanks studman you have most likely answered a question that lots of people have been many to ask.
Take Care,
Old Sep 7, 2003 | 08:21 AM
studman's Avatar
JodyBerry: The reset procedure resets all of the "learned" settings of the ECU. It does not revert your advanced timing settings, etc that were done using a Consult-II. When you drive the car after the ECU reset, it will be in learning mode. I have found out that the learning mode is more than 100 miles but less than 200 miles from the reset.
Old Sep 7, 2003 | 09:39 AM
dobiegillis's Avatar
I have a stupid question. If I reset my ECU will this change auto transmission shift points? My tranny is way to sensitive and I'd love it if it didn't downshift when I just barely increase throttle.
Old Sep 7, 2003 | 09:50 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
That's a little more complex to solve than just resetting the computer. The tranny has it's own little computer (IIRC) that is networked to the primary ECU, and they "talk" to each other...
Old Sep 7, 2003 | 06:03 PM
BrandonSE's Avatar
i read the info on how to reset the ecu, i went outside right away and tried it... but i couldnt get it to work, i might be a lil' too retarded or does this not work for the 2k ??
Old Sep 7, 2003 | 07:12 PM
TitaniuMax03's Avatar
might take you a few times, the "timing" part has to be precise...
Old Sep 7, 2003 | 07:25 PM
trey
Won't all that pressing on the gas pedal flood the engine or something?
Old Sep 9, 2003 | 12:53 AM
ÀÜSSÎË's Avatar
Not with A E.F.I. Engine only with a Carbed Engine
litch
123
Jan 4, 2024 07:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
NissLover
Aug 22, 2015 10:26 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
