Haveing problems with my tail lights
Old May 29, 2003 | 08:29 PM
ManualMaxima's Avatar
5th Gen till she dies!
I am Haveing problems with my tail lights. Sometime my driver one will be on, and other times it will not turn on at night unless i hit the breaks. What could this be?
Old May 29, 2003 | 11:42 PM
markargente's Avatar
The light is a dual filament bulb. The dimmer bulb filament could have burnt out but the brake light still intact. Try replacing the bulbs. I believe they are 1156.
Old May 30, 2003 | 07:21 AM
cam_honestiam's Avatar
1156 is the single-filament. You need 1157.
Markargente is right, with two filaments, the 8 watt (on with tail lights) is probably blown. The 27 watt filament (comes on with brakes) is still working. Your only other guess would be a short in the wire, but if one works always and the other does not, replace the bulb.
Old May 30, 2003 | 07:45 AM
bananamax's Avatar
short in the wire
short in the harness
short in the plug
sort in the connector
moisturein the plug
throw a multi-meter on it and se what she tells ya.
Old May 30, 2003 | 10:46 AM
thank you all so much
SmokinMax02
18
Sep 11, 2015 12:25 AM
Maxilano
Aug 31, 2015 07:33 PM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
yat70458
Aug 3, 2015 01:16 PM
