Frankencar intakes
Old Jun 20, 2003 | 05:35 PM
92 SE-R 02 SE
Frankencar intakes
Anyone break the strap that goes from the top of the drivers side strut mount to the intake itself? I was checking my oil today and i noticed that it snapped in 2 pieces! The filter is still tight..I wonder if i email them if they would send me a replacement piece. Its made out of some cheap metal, no wonder the torque of the 3.5 broke it!
BTW, anyone check out there webpage? they modified it with some Flash stuff..pretty cool!
Old Jun 20, 2003 | 06:03 PM
clipse's Avatar
You must be packing some serious power to make the support bracket break in two
Old Jun 20, 2003 | 06:04 PM
Maximam's Avatar
Re: Frankencar intakes
You need to isolate the intake from the motor. This is done on the stock box and should also be done on the Frankencar. Get an isolator from the midpipe to the throttlebody.
Old Jun 20, 2003 | 06:21 PM
92 SE-R 02 SE
Re: Re: Frankencar intakes
Im not sure what you mean?
Old Jun 20, 2003 | 06:33 PM
Maximam's Avatar
Re: Re: Re: Frankencar intakes
The flexible coupler that is connected to the stock box. Between the TB and the silencer. I believe the Altimas works well with the Frankencar. This will allow the motor to move freely and you won't have this problem. Also why not reduce vibration to the MAF. Mine is installed this way and works great. Look through the hood while in neutral and rev the motor, it rocks quite a bit. Under load even more. Nothing IMO should be fixed to the chassis from the motor
Old Jun 20, 2003 | 06:35 PM
clipse's Avatar
Re: Re: Re: Re: Frankencar intakes
Are you talking about the stock rubber accordian looking coupler thats is on the TB???
Old Jun 20, 2003 | 06:38 PM
92 SE-R 02 SE
Re: Re: Re: Re: Re: Frankencar intakes
Old Jun 20, 2003 | 07:00 PM
Maximam's Avatar
yep
Old Jun 20, 2003 | 07:03 PM
Greek to the Max's Avatar
We had a large discussion about this last week. Its very important to use the coupler, in order to allow engine play.
Old Jun 20, 2003 | 07:06 PM
92 SE-R 02 SE
does anyone have pics? i have my stock airbox, so i think i can make it happen..
Old Jun 20, 2003 | 07:17 PM
MiniRX7's Avatar
That bracket is actually scraping the A/C lines under neath.. For temporary i wrapped the lines with electric tape...
Do we really need this bracket on?
ED
Old Jun 20, 2003 | 08:33 PM
KLOOGY's Avatar
L33t BMW Drivah
I snapped that bracket at the track due to some ridiculous wheelhop....
Old Jun 20, 2003 | 08:48 PM
MiniRX7's Avatar
Hey watch it kloogy, i fyou were able to snap this brakcet you might have broke some engine mounts as well...
I broke my 2k2 engine mounts at a drag strip because of wheel hop..
ED
Old Jun 20, 2003 | 08:53 PM
KLOOGY's Avatar
L33t BMW Drivah
You might be right. Im going to the dealer tomorrow, and will have them check. I snapped so many engine mounts in my Stang due to drag radials...
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
