injen intake ? different makes???
ok guys i have a injen intake off a 98 maxima i bought it used. i have a 96 max. i have it installed and have had a starting problem eva since i installed my intake. had it wabout 6 month on. .i heard they make different ones for each year? from 95-96 & 97-99 is this true and whats the differents between those?
injen intake
wat model number do you have? i have the rd 1930 which is prolly the same one you have. ive had mine for like a year now.. and i dont ahv problems wit starting. i dont think the intake is touching the starter or anything taht would cause a hard start or anything??? is the filter touching the transmisson cable at the bottom? dont think that would matter.. but still. how many miles do you ahve on the car? you prolly need a new starter. check it. peace
DiZ
DiZ
then would the intake air sensor casue hard starts??? how do i find the part number on the intake.
ps: i have a new nissian starter (upgrade high TQ more teeth etc. starting problem got alot better after that. but still have it sometimes
A failing crank or cam position sensor will cause hard starts.
So will an out of spec Engine Coolant Temp Sensor.
You can also try to cleaning your throttle body.
Go to www.motorvate.ca for detailed instructions.
Originally posted by njmaxseltd
No.
No.
well i already changed both crank sensor pos,ref. just didn't change the cam sensor tho but no check engine light tho.
so i should just leave air temp sensor alone then???
