need help with supercharger
Old Jun 29, 2003 | 10:02 PM
lowmaxima's Avatar
hey what's up guys and girls. i need some help with my supercharger it has blown two belts within a matter of a month is there any idea on why this may happen and is there any good shops that work on chargers around new england area.. thanks alot for the help in advance
chad
Old Jun 29, 2003 | 10:12 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Get a stronger belt. Get a Dayco Poly Cog belt at your local Autozone or whatever. 69.5" length.
Old Jun 29, 2003 | 10:31 PM
lowmaxima's Avatar
thanks for the help.. also do you know the length belt for a 12 psi pulley
Old Jun 29, 2003 | 10:35 PM
[maxi-overdose]'s Avatar
if the belt is shredded, take a look at this.
http://forums.maxima.org/showthread.php?threadid=201651
Old Jun 29, 2003 | 10:55 PM
lowmaxima's Avatar
i see what you are saying but i still have my stock pulley on.
Old Jun 29, 2003 | 10:58 PM
still, if it is not aligned, the SC will shred a belt every month. have you use my method and check on your idler pulley and see where does it land?
Old Jun 29, 2003 | 11:06 PM
lowmaxima's Avatar
not yet. i should probably do that
Old Jun 29, 2003 | 11:08 PM
Craig Mack's Avatar
Oh sorry...my bad....69.5" is for 3.25-3.125" 10psi on the V1...I'm an idiot. 12psi for the V2....type belt sizes or belt(s) in the search exclusively in the SC forums and it lists all the sizes for V2 belts. You'll find your answer there.
Old Jun 29, 2003 | 11:18 PM
lowmaxima's Avatar
yeah i found the answer thanks alot for the help
Old Jun 29, 2003 | 11:22 PM
Craig Mack's Avatar
no problem
Old Jun 29, 2003 | 11:47 PM
lowmaxima's Avatar
how do you do the idler pulley test.
Old Jun 30, 2003 | 12:21 AM
compare where the belt lands on the idler pulley to that of the tensioner pulleys. if sections of the belt are off on these two pulleys, then you have the belt is not aligned.
another tip is when you put the belt back after the install, do not loose the idler pulley nut all the way. just loose it enough to slide the pulley along with the bracket and make sure it does not wobble.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Cumalot
Nov 28, 2000 09:38 AM
Mabfnar
Oct 24, 2000 11:17 PM
