MAF failures only on Franken intakes?
Any MAF failures happen with other intakes? Injen/JWT/Stillen?
Can one replace and update MAF #22680-AM600 without taking to the dealer? How much is it?
I don't even know why i'm posting my .02 because as soon as I say this it will break but I've had my Injen on for almost a year now and no problems with my MAF "YET"... Knock...Knock...Knock...Knock...Knock...Knock...Kn ock...
I think it may be vibration that causes many of the maf failures. My maf died after a single day with the franken/apexi combo. I noticed where it had been hitting and rubbing against the strut tower enough to wear the plastic from the sides of the filter. I'm gonna have to figure out how to rig up a decent mount before I put the intake back on.
What do you mean???
What do you mean???
)So the car will not know the difference between sensors and pop a light on me?
Originally posted by MannyNJ2k2max
Only changing the MAF is nescesary- I was not sure if the ECU had to be re-programmed(I heard someone mention this in the past
Originally posted by MacAlert
Where is the part number on the MAF?
IT is on the FRONT SIDE of the air tube ( the cooling fan side ), you may need a small mirror and a flashlight. Slide mirror down in between the air tube and the air box and you will see the numbers and letters.
I'm looking to get a intake and am leaning hard to a CAI. I am very concerned with all this talk of MAF failures. I hate to ask.... but are there any other quick comments on this subject??? I used to be an Helicopter mechanic in the ARMY and have a pretty mechanical backround, but this one has got me thinking. Thanks for the input!
Originally posted by DouglasM5
Bone stock 2001 w/41k miles. Wife's car, seen WOT only once (when I borrowed it.) Blown MAF, dealer says $675.00, not under warranty.
Any suggestions?
Any suggestions?
Originally posted by Rogo98SE
PM DaveB, You only need to replace the sensor inside the housing. Dealer won't tell you that. It's like 75 bucks.
DaveB is da man!
He was willing explain the situation to me over the phone so I ordered the part from him. It arrived the next day. Disconnected battery. Took me 30 minutes to replace part (I was being extremely careful and was a first timer).
Problem fixed - no CEL.
Oh, and I saved $570.00
Thanks to this board for your advice and many thanks to DaveB!
TallTom
57
Oct 14, 2025 05:16 PM
maxima297
Sep 30, 2015 03:32 PM
