If we have front wheel drive why do the back tires go bald first ???
are you certain that the rear tires are aligned, and balanced.? if not then that is your problem, or that your doing too many ebraking
seriously, the fronts should die before the rear, more load and more use in the front. make certain that you rotate the tires every 5k or so.
Re: If we have front wheel drive why do the back tires go bald first ???
Originally posted by ILOVEMYSE why do my back tires always go bald first
even on my dads 98 durango the fronts tend to wear quicker than the rears because of the turning, then again it could just appear that way because the tires do turn, taking more of a cross bite out of the tread.
getting on the gas quickly changes wear patterns though
along with what Izzy said, check tire pressure.
If we have front wheel drive why do my back tires always go bald first
Make sure your struts aren't wiped out too, though that doesn't sound like the problem here.
criminalslang810
Aug 16, 2015 08:12 AM
BassAddictJ
Aug 4, 2015 11:38 AM
