Can't remove valve caps!
Old Jul 27, 2003 | 05:17 PM
SupaFly's Avatar
Hey, I attempted to post this in the general forum, but i'm ansy and haven't received any responses.
I was hoping someone could give me an answer to a problem i have. I bought some valve caps from autozone a few months ago. I had a flat tire and when it was getting fixed, the shop couldn't remove the cap so they had to cut the valve off. I assume it has to do with the difference in metals.
I decided to check the other tires and i can not remove any of the caps. I've tried using two pairs of pliers (one to twist the cap while the other holding the rubber) to no avail. Does anyone know what options i have? Do they all need to be cut off? If so, what is involved and how is a new valve installed? Thanks in advance.
KC
Old Jul 27, 2003 | 07:08 PM
2MuchMAX4U's Avatar
Re: Can't remove valve caps!
Never heard of this one, before are the valve caps plastic or some aftermarket ones? Cause you could use a razor blade to cut the plastic cap off, the top of the valve stem is metal so it should be ok if cutting the plastic cap off. That way you wouldn't need to replace the valve stem. Oh you said this is the second time this has happened? Cause I thinks it might be time to leave the caps off!
Good luck
Robert
Old Jul 27, 2003 | 07:16 PM
SupaFly's Avatar
Re: Re: Can't remove valve caps!
Good luck
Robert
They are a set of aluminum caps, not plastic. I think the difference in metals (copper to steal) is the cause. Maybe rust?
I never said this happened two times though..
I have a feeling that the stems will need to cut. If that's the case, then they will have to take off the tire and remount and balance them. These $10 caps will end up costing me about $50.
Miket2006
Mar 1, 2021 03:55 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
