car does minor jerk like its choking....
Old Aug 10, 2003 | 11:50 PM
meccanoble's Avatar
Sports Button FTW
i get no codes or anything but i'm not happy with the way my car drives. Not as smooth as it used to be. Cant be my driving which is easily debatable between some of u . What i see happening is when i start off in a gear and floor it, i get this burst then a quick choke and then a continued burst...like a chatter but feels like a choke. If i put more gas its very unnoticeable but i feel there's a definite difference. Also i feel slower, not sure if its cause 17's put back on or what. Both problems may be associated with each other.
I was wondering about the following things?
spark plugs?
clean throttle body?
enough air going into crank and other two connects from midpipe?
no knock sensor code or anything...what do u guys think is the problem?
Old Aug 11, 2003 | 02:51 AM
maseo77's Avatar
i feel the same thing around 3800-4000 rpm then the power jumps back up after???
Old Aug 11, 2003 | 05:44 AM
njmaxseltd's Avatar
My guess would be the KS doing what it's supposed to, retarding timing a bit. It could be slightly over active, but still within operating range, hance no code for it.
Try switching your brand of gas and adding octane boost to further prevent any detonation that the KS might be picking up.
Old Aug 11, 2003 | 09:22 AM
SonicDust187's Avatar
njmaxseltd: I was trying to check for codes on my friends 99 Maxima non SEL however there is no screw on the ecu to turn. How else can I check for codes?
Old Aug 11, 2003 | 10:26 AM
njmaxseltd's Avatar
A scan tool.
Old Aug 11, 2003 | 10:59 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
IIRC those pretty much have a 5th gen. ECU, which requires an OBD scanner.
Old Aug 11, 2003 | 11:02 AM
nadir_s's Avatar
vicodin ... gift of life
go to pepboys and have it scanned for free. wait, they do it for free, right?
Old Aug 11, 2003 | 11:16 AM
Dave B's Avatar
Not DAVEB the parts guy
Could possibly be slow reacting 02 sensors. They won't throw a code either. I had some pretty bumpy part-throttle hesitation from 3000-4000rpms. I decided it was time to change out my 7 year-old 97K front O2 sensors and sure enough the hesitation disappeared and mpgs went up a couple. If you're experiencing problems above 4000rpms, then it's not your 02 sensors.
Dave
Old Aug 11, 2003 | 02:27 PM
meccanoble's Avatar
Sports Button FTW
thanks for the feedback guys. My hesitation comes very early. I get the hesitation in second gear at like 3-4 rpm...its like it comes in like .4 seconds after flooring it in the gear. I always use 93 octane and i normally go for the more expensive stations like Mobil, Gulf, Exxon, etc. I dont know if my knock was ever changed but one of my 02's were...
Old Aug 11, 2003 | 08:37 PM
meccanoble's Avatar
Sports Button FTW
forgot to mention i also get it in 3rd and 4th gear....
Old Aug 11, 2003 | 09:18 PM
Dave B's Avatar
I vote O2 sensors. Also check you knock sensor and knock sensor harness with a voltmeter. No point in changing things that are running perfectly fine.
Dave
Old Aug 11, 2003 | 10:39 PM
meccanoble's Avatar
Sports Button FTW
Dave
very true. so what do i do with a voltmeter? keep car on, put voltmeter on knock sensor and if it shows 0 then i need a new one?
Old Aug 12, 2003 | 12:41 AM
Dev's Avatar
Dev
there is a screw in there...its a very small phillips head screw
i have a 99 and its not a flathead like the rest of the years
mecca, seems like your car is misfiring...you might want to check your spark plugs, and ignition coils.
even if the CEL is not on, check for codes.
when my car was misfiring, it told me which cylinder was bad, so i replaced the coil and all is well now.
Old Aug 12, 2003 | 03:05 AM
meccanoble's Avatar
Sports Button FTW
i checked for codes a few times as recent as a week ago, and didnt get no codes except the one saying "car is fine"...
how much r coils?
Old Aug 12, 2003 | 11:48 AM
VQdriver's Avatar
i get sort of a slight hesitation from medium throttle when i'm quickly upshifting from 3th to 4th. sometimes i get this sort of split second bog that feels like the clutch is touchy, but in reality the shift was performed smoothly. perhaps i was shifting too fast? after this hiccup the motor is running like usual.
Old Aug 12, 2003 | 04:12 PM
Dev's Avatar
Dev
how much r coils?
unfortunately...they're very expensive from the dealer
i actually got a set of 6 from a blown vq for very cheap
instead of getting them new, i'd get them used if they are in working order.
Old Aug 12, 2003 | 06:14 PM
meccanoble's Avatar
Sports Button FTW
dam, i'll probably look around 4 dat
Old Aug 13, 2003 | 03:26 PM
190hpKiLLA's Avatar
Granny Driven
Nope, there is nothing there just like the 5th gens. There is a hole but no SCREW. Only 88-99 1/2 have the screw 99 1/2 + dont. So u have to use the OBDII scanner.
Old Aug 13, 2003 | 07:05 PM
ivelweyz
coil packs maybe...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
stromm
Aug 27, 2015 04:13 PM
maxima297
Aug 3, 2015 12:50 PM
