Noise From Front Wheel Please Help !!!!!!!!!
Old Aug 20, 2003 | 02:46 AM
Reaction021's Avatar
My Front wheel recently have this weird noise when it's running like A vibration or a humming noise at low speeds could this be an bad wheel bearing any advice would be greatly appreciated!!
Old Aug 20, 2003 | 07:00 AM
nitroz's Avatar
Does this get louder when turning to the side with the noise? I had my wheel bearing go out, the roar gets really loud eventually.
Old Aug 20, 2003 | 08:25 AM
astil's Avatar
it may also be a an aneven worn tire or it culd be the bearing. I remember driving an older Accord with worn tires,and boy,they were loud (huming)...it made a lot of difference with other tires on it. So,if your tires are worn that may be one cause.
Old Aug 20, 2003 | 12:39 PM
doesn't seem to make much noise during the turns straight road seem to be more noticable or maybe i don't pay much attention during turns or it could be my worn out tire they r almost gone already i'll guess i'll bring it to the shop for them to have a look at it but just keep the info coming Guys THANKS !!
Old Aug 20, 2003 | 01:00 PM
JPMax's Avatar
What's next!?..
Its most likely the worn out tires you have.
See if they are unevenly worn at all. (More worn on the inside than the outside, bald spots, etc.) Signs of bad alignment.
Old Aug 21, 2003 | 10:44 AM
i just went to the Shop today and they said i have a bad Axle on the left could that be the issue guys ???
Old Aug 21, 2003 | 10:49 AM
nitroz's Avatar
Always get a second or third opinion. Make sure everyone says the same thing to protect you butt from BS.
Old Aug 21, 2003 | 12:48 PM
maxcross's Avatar
It is unlikely that the axle is the problem unless the boot is leaking or cracked. I drove for almost a year with a torn boot and the axle didn't really have a stickyness about it. The bigger issue was the wheel hub bearing. Try to take it to a Nissan dealer to at least have them examine it, then maybe go somewhere else to have it repaired.
Old Aug 21, 2003 | 11:53 PM
i just changed the Axle and the sound was still there that sound only seem to be there when i am on the Gas if i'm on Neutral and the car is moving that sound doesn't seem to be noticable what u think could be the issue Guys
95 Maxima GXE with 135K 5 Speed
Old Aug 22, 2003 | 12:58 AM
kyllr's Avatar
just had similar problem but mione sounded like that all the time. It was my front right bearings going out. I waited so long to repair it so it messed up my wheel hub had to get that replaced too.
Old Aug 22, 2003 | 12:54 PM
i'll go take a look at that and keep u guys posted
Old Sep 2, 2003 | 10:57 PM
iansw's Avatar
Was it a humming sound that was rythmic with the spin of the wheels and almost sounded like rythimic wind or road noise?
Old Sep 2, 2003 | 11:54 PM
kyllr's Avatar
exactly as you describe
Old Sep 4, 2003 | 06:03 AM
maxcross's Avatar
the hub bearing is a metal on metal rubbing sound that is not necessarily constant, usually a half rotation occurance. you can usually feel it in the wheel and pedals. You know what, forget it...If something sounds weird, get it looked at. It seems as if a new thread about this is popping up twice a week. Read the previous threads as far back as you can tolerate.
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
