I knew it....VI not always opening!
After going to the track a few days ago my trap speeds and ET's weren't what I thought they should be. I seem to be a couple tenths and a couple mph slower, most of the time, than others with the the JWT/ECU, VI and similar other mods.
My harlan is mounted under the hood, so I rewired it into the cabin and mounted it on top of my dash. Went to the highway and made some 2nd and 3rd gear runs to activate the VI. After about 5 or 6 activations of the harlan it flaked out on me and started blinking. After that the VI would not open until the car was turned off and back on again.
Looks like I am going to have to go with another rpm switch.
can u use this one? http://www.mpsmall.com/mps/products/msd/ http://store.summitracing.com/produc...earchtype=ecat
if u have the $ u can get this one http://www.biondoracing.com/RacerEssentials.shtml
I know of one from summit racing that I might use. It could be that first one, but I didn't think it was made by MSD.
Now I'm beginning to worry about mine. I do have a light hooked up to my RPM switch and haven't seen it not come on though. Who knows what's going on under the hood though. Enough people have reported problems with the harlan that I think I would swap it out first chance I get. Let us know how the summit racing switch goes.
ZuM
ZuM
couldn't you use hte directions to make a shift light work for hte VI, just take the wire that will power hte light at a certain rpm and run it to hte VI?
http://www.maximadriver.com/modules....rder=0&thold=0
Mine flakes out every once in a while and it's always done it since I bought the unit a year ago. I just run a toggle switch if I see it flake out during a run. Sometimes I'll just flip the switch at the top of 2nd and just leave it open the whole rest of the run.
Dave
Dave
http://www.maximadriver.com/modules....=0&thold=0
Yup, I noticed that too! When I ran mine on the dyno, it occasionally would not open. I don't know why. Guess it's a little flaky. I also bought the MSD one but found it was huge unlike the harlan which was nice and small and didn't need any "pills"
The bad part is that once it flakes out it wont work again till the car is turned off. I wonder how many times I drove around w/o a functioning VI. I wasn't for sure, but I knew I usually was not getting the top end power I should have.
That's the great thing about the toggle switch. I flip it a couple times and the Harlan clears it self of the "flake" instead me having to restart the car.
Dave
Originally posted by Dave B
Yep.
Dave
Yep.
Dave
Nealoc mentioned a switch from summit racing. Search is dis-abled, so I couldn't find the thread.
You should look for that one. He had to set to something 2600 rpm to open correctly at 5200 rpm on the maxima becuase the switch was made to really work on 4 bangers or V8s, don't remember exactly.
It may be quirky to set, but apparently at least it's reliable, un-like the Harlans.
DW
You should look for that one. He had to set to something 2600 rpm to open correctly at 5200 rpm on the maxima becuase the switch was made to really work on 4 bangers or V8s, don't remember exactly.It may be quirky to set, but apparently at least it's reliable, un-like the Harlans.
DW
DW
DW
Anybody want to buy a used harlan
