breather filters.....
I think I might have a good question..well I just installed my JWT intake last week and love it...well I was showing one of my friends yesterday and asked why is there no hose connecting to one of the open tubes leading into the engine...well I told him once I took off the stock airbox and put the JWT in there was no other end to connect the tube to...he told me that I need something to cover it cause dirts gonna be sucking into the engine...is this true? can I use one of those little breather filters in it?
I had the same question about that hose before...couldn't find anything to connect it to. My mechanic told me that it's a air release hose for the transmission and should be kept unplug. FYI: My mechanic works for a Toyota/Lexus dealer so I am not sure if his answer is correct?
Those breathers need tap into the main intake from the MAF for a reason. If you just put some stupid filter on it your engine will suck through unmetered air and perform more inconsistantly.
Originally Posted by 2k2PhatMax
i put one on mine... can u explain more whys its bad?
check out this thread.
Originally Posted by MaxDoogie
the $5 ones from pep boys won't fit on the crankcase, the joint is too small to fit over the piping...Kev got a K&N one that worked perfect, you may want to PM him and ask what he got
they will with a little trimming
Air Breather Filter
hhmm...I wonder why I couldn't get mine to fit...did you guys get the APC brand one, or something different? the tubing was way too small on the one I got, I greased that bad boy up, and I still couldn't get it to slide on
Originally Posted by maximaman777
thanx..I tried that and nothing helpful showed up for me...so Im hearing "no" dont get the breather cause it will throw me a SES light and "yes" it works...if not than what will be worry free??
I had a K&N Breather Filter on mine and no problems. I was told that all that port does is help increase exhaust flow. I've since put the stock airbox in and reconnected the stock hose. No problems still. Chris
I was getting random misfires because I was running lean, even at idle. As soon as I took it off it went away. As adding one of these does nothing for performance I'm not worried about not being able to use one.
If you want to try and keep your TB & intake manifold cleaner try an inline filter. It maybe prone to clogging over time but they're easy to install and cheap.
There are also more elaborate filters like these:
LEIF® Reservoir Breather Breather Tank Kit
MaximaDrvr
Aug 19, 2015 08:20 PM
Zprime
Jan 19, 2001 01:42 PM
