Catz Zeta00 lighting upgrade...
Old Feb 10, 2001 | 10:27 PM
NightRider's Avatar
I just purchased the Catz Zeta lighting upgrade and installed it today. All I can say is wow! The lights are much clearer and don't dim after a while. From a driving perspective it looks much whiter and now I can see further out. Zeta00 enhances your lighting system by using HID like ballasts to regulate the voltage at 15.78v all the time. Its just like getting a bigger alternator, but it doesn't rob power from your engine. Right now I'm using it with the PIAA Platinum series lights. Now the lights are very close to HID color. Other lights can be used as well as OEM bulbs. NO OVERWATTAGE BULBS can be used because it is not a harness upgrade. I'll find out if it can be used in conjunction with the APC Super Harness to run higher wattage bulbs. Overall a good lighting upgrade.
Old Feb 10, 2001 | 10:41 PM
SWEETSOUND2001's Avatar
where purchased? how much? easy to install? thanks Anton
Old Feb 10, 2001 | 10:52 PM
NightRider's Avatar
I purchased it from Audio Connection in Columbia, Md. It costs $219.00. The installation was easy! all you have to do is plug the fuse jumper into your fuse box, ground the ballast and mount it. You can check is out at
http://www.fet-usa.com/shownews.asp
Old Feb 11, 2001 | 02:32 AM
theres so much stuff there. can you give me an exact part or model # ? or the webpage # ? thanx
Old Feb 11, 2001 | 02:23 PM
NightRider's Avatar
The link takes you right to the Catz Zeta00 page. Click on the green Zeta link to see the info..
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
