Catz Zeta00 lighting upgrade...
I just purchased the Catz Zeta lighting upgrade and installed it today. All I can say is wow! The lights are much clearer and don't dim after a while. From a driving perspective it looks much whiter and now I can see further out. Zeta00 enhances your lighting system by using HID like ballasts to regulate the voltage at 15.78v all the time. Its just like getting a bigger alternator, but it doesn't rob power from your engine. Right now I'm using it with the PIAA Platinum series lights. Now the lights are very close to HID color. Other lights can be used as well as OEM bulbs. NO OVERWATTAGE BULBS can be used because it is not a harness upgrade. I'll find out if it can be used in conjunction with the APC Super Harness to run higher wattage bulbs. Overall a good lighting upgrade.
I purchased it from Audio Connection in Columbia, Md. It costs $219.00. The installation was easy! all you have to do is plug the fuse jumper into your fuse box, ground the ballast and mount it. You can check is out at
http://www.fet-usa.com/shownews.asp
fastcarny
10-06-2015 10:42 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
