need every1 opinion, what can i do to stop my lights from dimming??
i have a pioneer 700 watt amp bridged pushing two 12" fosgate hx2 (think 1000 watts )
i also have a 1 farad cap connected
with the cap still conected to the system my lights will dim out every time the bass hits,
will the lights wen they dim , will that cause my battery /alternator to to fail ?
do i need a better battery or another cap ? or anything else?
would gettin an optima battery solve this problem ?
should i get another cap? i taught a 1 farad cap is supposed to be good up to 1000 watts , i only have a 700 watt amp
if i leave my lights dimming will it cause my battery/ alternator, wire harnesses, etc to burn out
thanks for any help
thanks for any help
97 out of 100 times you don't have a good ground. You aren't running enough power to overload the stock system. Make sure your ground is the same size wire as the positive, and is grounded within 18 inches of the amp. Make sure there is no paint where it is grounded, and make sure your ground is tight.
Originally Posted by Igor911
you might want to upgrade to a bigger cap....
you hit the power lock and the lights dim.
you go up with the windows and the lights dim.
i only have 2 amps.
the only way i helped my system was by adding:
new 125 amp altinator (oem)
2- optima red top batterys
2- 1 f caps.
i just checked the ground everything looks fine , its about 12 inches away from the amp, there is no paint on the surface n the ground wires are the same
97gles wow all that work , does your lights dim at all?
also wat would happen if u leave ur lights dimming , would it possibly burn out the battery/alternator , wire harnesses?
it's very easy to kill a battery but you don't want to kill the alternator. it will cost alot of $$$ and down time to fix.
i rather change the battery 10 times before i have to change the alternator.
listen to me man.....this is my 2nd max....this is a common problem. on the 1st max...i rebuilt my alternator from 12 to 14volt, without a 1 farad cap, new gold series sears battery pushin 500watt 2ch FOSGATE amp n 600watt 4 ch AMPLE amp, but now i have (2) 1 farad caps, red top OPTIMA battery pushin 750watt mono MTX amp n 600watt 4 ch AMPLE amp. no probs now...but im gonna install crazy TV's, so im adding a 2nd OPTIMA battery in the back.
if you are running more than 14.5 volts that means your regulator is shot & your amp will break down soon.
i went from a 110 amp to a 125 amp (oem)
you can get a 180 amp alternator from ohio generators but you will need to install new brackets so it can fit.
Man I don't know what ya'll are talkin about as far as the max having chronic problems with the lights dimming.... I have 3 power HX2 12's, with 3 fosgate bd.1000 amps, I hit 152 db all day long, and I still have my stock battery with no caps.
My Lights are bright and pretty, with no dimming....just a thought
You may want to start rewiring the stock wires under the hood.I have 0 guage run over to the engine block, and that took care of a few problems. I have better throttle response (better spark) and my big Xtant amp doesn't dim my lights at all. I also have 0 guage run to the trunk, and a stainless nut, and bolt with lock washer to ground it in the trunk. I haven't had any light dimming problems with Maximas. I just installed a 1600 Watt RMS PPI amp in my friend's car with no problems.
tsi6001
Oct 3, 2022 10:23 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
