mistake when checking ECU
Old Oct 4, 2003 | 03:14 PM
aznpo1o's Avatar
dah...I had trouble turning the ecu thing since my screwdriver (only one) was slightly too large. messed up the plastic to turn it and while fiddling with it...made the 'check engine' light turn off without seeing the flashing lights....any way to turn this back on?
Old Oct 4, 2003 | 03:25 PM
SXN's Avatar
SXN
so wait... did you strip out the screw head or what? im a little confused with ur post
Old Oct 4, 2003 | 04:13 PM
ivelweyz
What plastic? There is no plastic exposed on the ECU. If you didn't break anything just check the codes again...
Old Oct 4, 2003 | 04:39 PM
SXN's Avatar
SXN
yea, thats what confused me too
Old Oct 4, 2003 | 06:40 PM
aznpo1o's Avatar
no...I reset the ecu so the light went off, but I never got to see what code the light was blinking out
Old Oct 4, 2003 | 06:49 PM
nismomaxima97's Avatar
I don't think so you can check the code once it has been reset. All data is cleared I beileve, unless the OBD scanner can do something special that i don't know about. I say just wait and see if it comes back on, that's my best bet.
Old Oct 4, 2003 | 07:07 PM
Gen8888's Avatar
When you say messed up the plastic, do you mean the plastic that is covering the screw you have to turn to reset/check your ecu? That is just the warning sticker and supposed to be ripped to get to the screw. Just do the diagnostic self test and see if you get any codes.
Old Oct 4, 2003 | 07:45 PM
ivelweyz
That's not it since he had to remove the sticker to get to the screw in the first place. The codes will return after a few day s or sooner. If they don't you need a new knock sensor since that code doesn't return for weeks...
Old Oct 4, 2003 | 10:19 PM
SXN's Avatar
SXN
well...dont just go out and buy a knock sensor because i didnt get another CEL
Old Oct 4, 2003 | 10:53 PM
aznpo1o's Avatar
I used too big of a screwdriver and messed up the inside plastic screw thing...does that many sense? I already broke through the plastic thing though it's the screw that's messed up
Old Oct 4, 2003 | 10:54 PM
SXN's Avatar
SXN
the screw is metal right? have i not checked my ECU for so long i forgot what it looked like?
gustavison
Oct 4, 2015 06:50 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
