can someone do a writeup on wiring a switch up to the drop resistor mod?
Originally Posted by MacAlert
All you have to do is disconnect the plus thats on the LEFT sturt tower.
Originally Posted by sloppymax
he is talking about wiring up a switch so you control when its on and off from inside the cabin. i dont know many people running around all the time with it unplugged. most people would just be interested in wiring it up to a WOT switch like jime has. this will work on 4th and 5th gen auto transmissions.
i was hoping to put a switch inside my cabin so i can jus turn it off when i want.. and for normal driving... have it back connected.... there were a couple people that have done that.. but as i am an electric newbie.. i dont kno the first thing about how to do it....
I haven't done this but I think all you need is a SPST NC switch (single pole single throw, normally closed, 2 or 3 contacts, if 3, the 3rd is usually not connected).
SPST NC: A___B
when pressed: A_/_B
Then cut only one wire going to the drop resistor. Attach one cut side to side A of switch and the other cut wire to side B. A WOT switch is probably best for this because it will only switch in at WOT and out otherwise.
hope that helps
SHIFT_woosh
SPST NC: A___B
when pressed: A_/_B
hope that helps
SHIFT_woosh
The Frye
Sep 2, 2021 11:03 AM
