Brighter Tail Light Bulbs?
Old Oct 27, 2003 | 09:43 PM
JetBlackMax's Avatar
I have altezzas obviously, and When the lights are on the tials dont look so bright because of the red lense. Is there a Clear bulb like our factory ones that would be a lot brigther to switch the stock ones out with so the RED from the red reflector is real bright? Thanks
Nick
Old Oct 27, 2003 | 10:00 PM
Max4U's Avatar
Nick
Maybe you can try LED bulbs. I would not recomend putting a higher wattage bulb unless you change out the fuse to a higher amp fuse. The fuse box is located under the driver side of the dash.
Old Oct 28, 2003 | 08:26 AM
Ladzio's Avatar
I have the same concern, Thanks for the input Max4U.
Old Oct 28, 2003 | 10:34 PM
Midknight MAXX's Avatar
SUPERBRIGHTLEDS
Old Oct 28, 2003 | 10:49 PM
1FSTMAX's Avatar
A few 55 watt bulbs should do the trick.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
