Code 01 01 Camshaft position sensor HELP
Old Nov 23, 2003 | 07:16 PM
newborn1281's Avatar
I have problemsstarting the engine got code for Camshaft Position Sensor.
Any help on it what is camshaft where is it how can i solve this problem?
Thank you
Old Nov 23, 2003 | 07:31 PM
Ramses718's Avatar
thats the sensor right infront of the tranny or just above it actually. I changed mine like last yr. It was wrecked held in place by dirt and grime.
Old Dec 3, 2003 | 09:41 PM
could sensor creat the problem?
Old Dec 3, 2003 | 09:43 PM
i have problem with starting the engine could sensor create thisproblem
Old Dec 3, 2003 | 09:53 PM
Ramses718's Avatar
Def, I burnt out my starter because it wouldnt start. Make sure you check both sensors though because I wasgettin the code for the sensor on the passenger side but it was the sensor on the drivers side that was no good.
Old Dec 5, 2003 | 11:57 PM
great thank you because its killing me one moment its working another its not. Is it possible that it would work one day ok and anbother giving head aches?
Old Dec 6, 2003 | 06:00 AM
Kevlo911's Avatar
Kevlo for President
DTC 0101 is caused by the Camshaft Position Sensor (Phase). This sensor is located on the engine front cover facing the camshaft sprocket. It detects the cylinder number signal. The Engine Control Module uses this signal to control spark plug firing order and also to sequence the fuel injectors correctly. If the CPS is bad the ECM will fire the plugs at the wrong time, or not fire them at all. This would account for a no-fire symptom.
Old Dec 7, 2003 | 09:34 AM
does any one have pictures of the location of the camshaft position sensor. Please help my car wont start.
Thank you
Old Dec 7, 2003 | 10:19 AM
help i need picture of camshaft position sensor and where is it located.
Thank you
Old Dec 7, 2003 | 11:10 PM
boris's Avatar
Thank you
It's the easiest sensor to replace ever.
There is one only Cam. Sensor (do not confuse with the Cram.Sensors)
Old Dec 8, 2003 | 05:29 PM
worm's Avatar
i had the same problem with the camshaft sensor, car wouldnt start and all that crap, replaced it and all my problems are gone.
until i got this stupid cylinder misfire. POS.
Old Dec 8, 2003 | 09:32 PM
boris's Avatar
Worm, how did you know it was the camshaft sensor going bad?
Got a trouble code? My car doesn't start but no codes.
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
