HELP!!! Car won't stay warm!!!
So it's ball freezing cold this morning. Go out and let car warm up for probably 10 minutes. Temp gauge is maybe half way up when I get back in. Turn on heat full blast and drive to work. Temp gauge goes down all the way to the cold mark!! Starts blowing luke warm air. I've never seen a car do this, hopefully it's only a thermostat, anybody else have a similar incident or ideas??
Thank you.
Thank you.
well, my friend didn't change his oil in his car on the regular scheduled time, so his engine wasn't running normal. The A/C was not cold and the heat was not hot. The car would not warm up correctly also. HIs temp guage was either low on C or more than middle. Then a few months later, his engine died on him.
Originally Posted by mzmtg
Your thermostat is stuck open. I was having the same problems as you. I replaced my stat with an autozone brand part this weekend and it's all toasty now.
Thanks! I'll give a new thermostat a try.
http://www.cybrrpartspro.com/Chilton...961CH03_5.html
Put this link into your favorites and refer to it often!
Thanks man, I take it I have a VQ30DE engine, right? (96'max)
So when the thermostat is stuck open, the car would cool down quickly? After I drive and turn off the car, the car gets cold quickly. The heater air is not that hot either
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
BobMax
Aug 15, 2015 12:35 PM
