wiring amp and sub to factory cd player
Old Nov 29, 2003 | 09:38 PM
kingkongkev's Avatar
I have a '96 ...just got an amp, sub, and wiring kit, but is it true that I need to purchase some converter so that i can have RCA outputs for the factory cd player? let me know please. as a matter of fact any type of info/suggestions is well apprecieated. thanks!
Kevin
Old Nov 30, 2003 | 08:39 AM
erty67's Avatar
Decal Specialist
Kevin
I just used a line-level converter from Wal-Mart($10) and tapped it into the rear speaker wires. i just had to drop the amps down off the speaker to get to the wires. Also, I used a test light to find the wire that turns the Bose amp on/off with the radio and I tapped my remote wire into it. Then I just had to ground it and run the power wire to the battery. Easy install. That wa in my 98 w/ Bose. If you have non-bose, you should be able to do the same thing but may need to run remote wire up to the HU. any other questions, feel free to PM me. Good luck.
Old Nov 30, 2003 | 09:13 AM
TAPOUT's Avatar
You will lose
Some amps have line level inputs as well as rca. If your amp has them, use them. There are also speaker level input detectors that will give you remote turn on if you don't want to take the radio out, and don't have Bose.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
