need help "89 GXE won't start
Old Dec 21, 2003 | 02:17 PM
Y2KMaxGXE-R's Avatar
To all the 3rd gen gurus, the car is in mint condition, 159K mi, except this one problem. The engine will start only after 10+ cranks. The starter is fine, battery is charged. Moving a gear shifter up and down sometimes known to help. The problem is getting worse in cold weather. Once the engine is running, there is no check engine light. Also, the engine tends to just cut off all of a sudden. Any ideas? Thanks
Old Dec 21, 2003 | 03:25 PM
rrrfoma's Avatar
it might be a rusty distributor rotor
Old Dec 21, 2003 | 03:43 PM
Maxima NutBag's Avatar
yeah, checking the distributor is a good idea.
Old Dec 21, 2003 | 05:02 PM
male's Avatar
Check the leads from your inhibitor switch. Maybe they are shorting or the switch is shot. Only explanation for wiggling the shifter making any difference.
Old Dec 21, 2003 | 07:27 PM
I'd rule out the distributor because the engine runs very smoothly (once started). Sorry for a dumb Q but what is an inhibitor switch and where is it located?
Again, the car is more difficult to start in cold (rainy) weather...
Old Dec 21, 2003 | 11:31 PM
MaximamixaM's Avatar
most cars have a switch that requires the shifter to be in park or neutral in an automatic in order to start. sometimes it wears out, or something, and say the car won't start in park, but will in neutral, etc.
Old Dec 22, 2003 | 05:52 AM
Need more opinions. Bump to the top
Old Dec 22, 2003 | 08:33 AM
Igor911's Avatar
My brother had same problem.. he changed the distributer and spark plug wires and it runs great now.
Old Dec 22, 2003 | 11:31 AM
Makes no sense. If the distributor was bad there had to be other symptoms like rough idle.
Old Dec 22, 2003 | 11:36 AM
Igor911's Avatar
who's car is this?
Old Dec 22, 2003 | 11:42 AM
Jeff92se's Avatar
I'm needing a caw
I agree. Check this first. Without confirming this, I see no point in guessing further.
Old Dec 22, 2003 | 11:44 AM
Igor911's Avatar
They also have a problem with that switch on auto 2k maximas. I know this from experience from when I had my 2k.
Old Dec 22, 2003 | 03:01 PM
male's Avatar
That't called the inhibitor switch. See my previous post
Old Dec 22, 2003 | 07:01 PM
ok inhibitor switch. Where is it located on 3rd gen, and how to diagnose it?
IGOR911: bish lol
Old Dec 22, 2003 | 08:38 PM
internetautomar's Avatar
mod or sell?
Fuel pump is failing!
I'll bet there is no fuel pressure in the system with the car off.
Not too uncommon of an occurence
Old Dec 22, 2003 | 08:41 PM
Igor911's Avatar
IGOR911: bish lol
you are a moron, next time u warn me i will u
Old Dec 22, 2003 | 09:07 PM
89badmaxse's Avatar
my max did the same thing and it was cuz my coil was goin out may not be the same thing for yours but it is worth lookin into.
Old Dec 23, 2003 | 07:31 AM
The failing fuel pump: is it possible to check the pressure on your own? How much is new fuel pump?
Old Dec 23, 2003 | 07:48 AM
mod or sell?
Yah, AZ should be willing to "rent" you a fuel pressure tester.
just not sure how to connect it.
Old Dec 23, 2003 | 08:26 AM
I may sound dumb here, but do you think it is possible to test by simply squeezing the fuel line?
Old Dec 23, 2003 | 08:34 AM
mod or sell?
nope......
Old Dec 24, 2003 | 05:54 AM
what is the location of the fuel pump and where to buy one for less $$?
Old Dec 24, 2003 | 05:56 AM
Pervis Anathema's Avatar
The fuel pump is bolted to the top of the fuel tank. It can be accessed by removing your rear seat. By a Walbro and save yourself some $$. Google it; I don't remember the address.
Old Dec 26, 2003 | 06:13 AM
Thanks guys.
markevans999
Oct 25, 2015 08:27 AM
QueensMAX
Sep 15, 2015 04:14 AM
rnb754
Sep 14, 2015 11:39 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
