How do you stop break squeaking?
Old Dec 30, 2003 | 02:11 PM
JeremyMarkham's Avatar
My breaks have been squeaking when I come to a slow and sometimes fast stop. It is driving me nuts! Is there a way to stop this?
Old Dec 30, 2003 | 02:14 PM
ABK's Avatar
ABK
Replace them (**nothing less then ceramic**), lube up the floating pins or whatever they are called, and check the rotors
Old Dec 30, 2003 | 02:29 PM
Its not an easy fix ey?
Old Dec 30, 2003 | 03:33 PM
outsider's Avatar
get oem brakes or one that you know dont squeak
Old Dec 30, 2003 | 04:47 PM
driver824's Avatar
from wht i hear non oem will always squeak. i have brembo cross drilled rotors and aftermarket pads. squeakes are always present but i have many other issues to fix b4 that. but def go with oem.. brake dust may be a common thing but at least when u roll up people wont run away...
blake
Old Dec 30, 2003 | 06:06 PM
Max Noob's Avatar
raybestos quietstops dont squeek.. ive had them for about 5 months now.. never had one squeek. about 40 bucks form kragen.. they are ceramic. dont double up the shims like my stupid butt did. ur initial bite response time goes down if you do that. jsut use th stock shims or the shims that come with the new brakes.
only other option is factory brakes. but those are pricey i think from dealer.
Old Dec 30, 2003 | 06:12 PM
packetattack's Avatar
Disc brake squeaking noise isn't always from the pad touching the rotor, but sometimes the pad vibrating in the caliper. I've always made sure that some sort of quiet stop additive was used on my pads when being replaced:
http://www.xkms.org/AutoBarn.com-3/CRC-Disc-Brake-Quiet-(4-oz.).htm
Old Dec 30, 2003 | 06:19 PM
twill's Avatar
yeah, when you get pads installed make sure you use some anti-squeal adhesive on the backside of the pads. Should keep them stuck to the caliper and minimize on the rattling that causes squeaking.
Had some non-oem pads and rotors for 1+ year and have no squeaking on my max.
Old Dec 30, 2003 | 06:23 PM
|Bijan|'s Avatar
UCF Lexus
brake squeal stopper
Old Dec 30, 2003 | 10:33 PM
ABK's Avatar
ABK
Yeah you got to use the anti-squeel thing inbetween the pad and metal plate to keep them from squeeling. Make sure you check the rotors. The job with replacing all the rotors and all the brake pads and hardware took me five hours with all the going to autozone and taking breakes. If you don't have to replace your rotors it will take you like 3 hours. The hard part is the rear calipers. It took me good half an hour to figure out how to properly get them back in.
Old Dec 31, 2003 | 06:26 PM
Max Noob's Avatar
Raybestos Quiet Stop pads came with soem anti seize looking stuff, that might tbe the brake squeel stopper stuff your taking about. anyways..it coems with it. it doent squeek.i recommend.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
maxima297
Sep 30, 2015 03:32 PM
