where to find/buy gates belts?
just wonder where i could buy gates belts from? i'm going to be getting UDP soon and i need 2 new belts.....any one know the part # for these belts? also, have you heard anything about Bando belts? are they any good? are they worth getting?
Originally Posted by ejj
You don't _need_ a gates belt. Any auto part store should be able to cross-reference the gates part number and get you a belt that will fit.
this is true, i went out and bought the gates belts according to custom maxima description i think it was, and one belt did not fit. dealership made call and some parts guy drove up with unknown belt, that was used.
Because the pulley on there is only made to handle a certain amount of boost I guess. Or it might be because the belt is too long to handle the speed of the pulley. With the UDP stuff will be spinning faster because the UDP itself is smaller than a stock one. I don't know, something like that.
True, but Gates belts are a better qaulitythen the average autozone $9.00 one.
How fast the pully is spinning doesn't matter...its the diameter of the pully that decides the speed of the blower, which of course determines the boost you'll create.
With a 6.25" crank pully and a 3.6" SC pully you'll spin the blower at 42,187.5 RPM. With a 5.5" crank pully and a 3.6" SC pully you'll spin the blower at 37,125 RPM. Noticably slower, and you'll create a lot less boost.
Reference:
http://www.vortechsuperchargers.com/...pspeedv-2.html
If you want more boost, you put a smaller pully on the supercharger, not the crankshaft.
from custom maxima site:
1995-2003 Maxima:
Alternator & Water Pump
1995-02 Gates # K060408
Power Steering
1995-02 Gates # K040292
If this one does not fit then try: Gates # K040300
you could keep reciepts and take one back !
1995-2003 Maxima:
Power Steering
Originally Posted by -=PK=-Maxima
i still dont understand.......is it bad to have a udp with a s/c? if so, why?
its bad. ejj basically explanied it.
with UDP you will not make as much boost.
why would anyone add a mod that takes away hp.
Way backwards dude.
Reference:
Reference:
here's a great site, just go to the part search section and enter the # belt u need
www.rockauto.com
www.rockauto.com
05' MaximaMan
Oct 8, 2017 06:36 PM
