gxe to se how to make keyless entry work
Originally Posted by TwoSlow2Go
i was tryin to make my gxe have keyless entry i got the box i plug it in but theres a pluig missing anybody know what to do
i think it's under one of the seats... not sure though. do you have the little red security light on your dash? if so, just get a remote and try to program it; worth a try.
p.s. just don't go to the dealership to program it, they'll rape you.
Did you have the red light?
anybody know what to check to see ifu have keyless entry and how to make it work
If your GXE doesn't have the security light near the steering wheel...you can't use the keyless entry remote. You need the the "Security and Comfort Package" in order for it to work. Since you don't have the Security Light, thus you cannot use the keyless entry remote.
it didnt have the security light so i went and to junkyard got it off another max and plus it in know what do i do where do i get the security n comfor package n how much is it
ok so u people are tellin me i have to run wires or not i got the keyless entry box for free n the switch i hooked em up im missin one ofr the connector that r needed to make the keyless entry work what do i do
, and try some capitals and correct spelling while you are at it.By keyless entry box do you mean the remote or the relay that plugs into the trunk? According to Daniel B. Martin in the thread I linked to above if you have a relay plugged into the brown connector in the trunk then all you need to do is get a remote.
I don't know if simply pluging the relay into the brown connector will give you factory keyless entry though. It could be that the presence of the relay means there is other stuff that you can't see in the car.
Here is my trunk with aftermarket power trunk release (I know it's ugly,but it works). You can see the brown plug for the stock keyless entry is taped up so I do not have it. However my aftermaret alarm has keless entry.
ah2002
Mar 9, 2016 01:42 PM
Ray229Harris
Sep 16, 2015 08:16 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
criminalslang810
Aug 16, 2015 08:12 AM
