????big brakes guys??
Old Feb 21, 2004 | 10:18 AM
crewchief264's Avatar
I need new wheels that can clear the franken car big brake kit?-not diameter I already have 17's and the 300zx caliper had to be ground on to fit. However I wondered if anyone on here knows what will work, as far as offset and backspacing. or type of wheel I'd like to stay with something like I have.
Old Feb 21, 2004 | 01:08 PM
BigDogJonx's Avatar
Too hard to say because each wheel is different in design and backspacing. I had to put 1/2" spacer in the front for my new wheels to clear my Wilwood calipers. My other 19" wheels (Momo M1s) had no problem clearing the caliper, it actually cleared it by almost 1-1.5"! My current wheels are also 19" +42mm offset. Even if I got the +38mm offset it still wouldnt have cleared enough. I needed a full 1/2" to get it to work.
Dixit
Old Feb 21, 2004 | 01:50 PM
rims?
bigdog your web page doesn't show very good pics of your current setup! Also what offset are you currently running? and did the spacers make much difference in handling? do you auctocross?
Old Feb 21, 2004 | 02:00 PM
mzmtg's Avatar
Minister of Silly Walks
So, why is this in the boost forum?
Old Feb 21, 2004 | 02:09 PM
why???
Because I'm boosted? and.... because alsong with more power comes with the ability to slow down power? the factory brakes suck. and pad upgrades help... so then i tried 300zx brakes and cracked the first set of rotors- cross drilled and slotted so then.... brembo slotted and hey warped in 2 two weeks. so.... now I'm getting wildwood 13 in brakes and need to get rims and I figured some of these guys have ran into same problem as I have, with speed comes the need to slow down---POWER....
Old Feb 21, 2004 | 03:38 PM
BigDogJonx's Avatar
Sorry I havent updated the website in years. It doesnt show anything about the turbo or anything nice
http://turbofedmax.com/fullpics/wilwoodbigbrake/ those are pics of the wilwood calipers installed with the old 19" Momo M1 wheels.
http://turbofedmax.com/fullpics/wheels/exel1.jpg
http://turbofedmax.com/fullpics/wheels/exel2.jpg
http://turbofedmax.com/fullpics/wheels/exel3.jpg
http://turbofedmax.com/fullpics/wheels/exel4.jpg
http://turbofedmax.com/fullpics/wheels/exel5.jpg
Those are pics of the new 19" wheels on there.
Handling no issue. The spacer really doesnt affect that once you get longer lugs on it (60mm Nismo ones, they the only company). I dont autocross.
Dixit
Old Feb 22, 2004 | 05:14 AM
big dog??
did those pics of the adrs you have clear the brakes? if so do you have any info on them??
Old Feb 22, 2004 | 11:47 AM
BigDogJonx's Avatar
Those ADRs were never installed on the car. But regardless, a 1/2" spacer wouldve made it clear just fine. Dont worry about issues on the rims not clearing, aint nothing that a 1/2" spacer wont clear.
Dixit
Old Feb 22, 2004 | 12:27 PM
wheel studs
which 60mm studs did you get from nismo? they show two different ones. and where did you get your spacers? Ithink I'll give them a try!
Old Feb 22, 2004 | 10:37 PM
BigDogJonx's Avatar
Call up courtesy nissan and tell them which car you have and he will make sure he gives you the right studs. One is specifically for the Z, the other is for the rest of the Nissans.
If you want, H&R makes 20mm spacers that come with the lugs and it usually runs about $100. OptionsAutoSalon.com usually has them for that price. To me thats a cheaper and better option then doing what I did.
Dixit
rbuswell
Nov 17, 2016 04:54 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
max1029
Aug 26, 2015 09:51 AM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
