Help! pics and sound, few questions... Long
Help! pics and sound, few questions... EDITED
There is a sensor on the engine that I don’t know what is does.
Does any one know what is it? http://www.cardomain.com/memberpage/497685/2
I was trying to find out what error codes I had on my car, and I think I over turned the screw (on the ecu), will that damage my ECU?
The Engine light of the car doesn’t turn on. Did the light bulb burned? It was working 2 days ago.
For the past 2 days I have had a weird problem with my idle.
1.The rpms go from 600 at idle to 400-300.
2.When I turn the car on right away the rpms drop to 600-400. (It never happened before, usually stays at 1000rpms for a few minutes).
There is a sound on my car, when I first turn it on in the morning. I have a 10sec, video with the sound.
http://www.geocities.com/guilhermenader/maxima95
tip: always sum up at the end as short as possible after all is written
you maybe have just cleared/reset your cel and that would explain why it's not back on. if the problem needs to be fixed, it will be back.
that looks like the wire used for the drop resistor mod.
your car doesn't sound so hot on start up...hard to tell by that sound clip, but generally a funny noise that goes with start up in the cold cold weather is just the starter sticking. regreasing it will usually get rid of that noise, i need to do that personally. not sure if your noise was different though cuz you describe it differently.
try to organize your post a little more and people will be more prone to answering. sorry i can't help that much, goodluck with your ride though.
Hey I found out the problem
I had left the ECU screw turned to the other side. All my problems were fixed.
sorry about asking so many dumb question, where if fact, the problem was me.
Mar 12, 2020 12:06 AM
ballerchris510
Sep 11, 2015 05:29 PM
