Anyone know how to reset the moonroof?
Old Feb 28, 2004 | 01:31 PM
trey
I had to disconect my battery for something and now my sunroof only goes up and down but not back. in otherwords it won't open,
can anyone help?!?
Old Feb 28, 2004 | 01:59 PM
2k3TitaniumSe's Avatar
Disconnect the battery again or take it to the dealer.
Old Feb 28, 2004 | 02:12 PM
trey
I thought i heard something about holding one of the buttons down for a certain amount of time will reset it or something like that??
the dealer is closed til mon. and if it rains, i'm screwed because it won't shut all the way.
anyone else have a suggestion?
Old Feb 28, 2004 | 03:13 PM
trey
Wow, can't believe nobody knew this. I found the reset intructions in the manual, just press the up or down button for more then one sec, depending if the sunroof is open or closed.
Old Feb 28, 2004 | 04:18 PM
MaxSE03's Avatar
Push the down button and hold it for a few seconds. It will reset and you will be good to go. It's also listed somewhere in the owners manual.
Edit: I didn't read your last post......
Old Feb 28, 2004 | 05:46 PM
Zero Deuce SE's Avatar
Some of us don't have moonroofs/sunroofs. Maybe you are one of the few that have had that problem. When all else fails, CTFM (consult the freaking manual).
Old Feb 28, 2004 | 05:56 PM
maximamaybe's Avatar
Mine has freaked out several times before. I usually keep pressing buttons and moving the switch back and forth. finally it comes back.
Old Feb 28, 2004 | 07:20 PM
03maximan's Avatar
I agree, this sunroof is wierd, sometimes you slide the switch back to open and it doesn't.
Then it's open and you move the switch a couple clicks and sunroof doesn't move until till you move it to close position. Thought about taking in to dealer but probable hear the old " it's operating the way it was designed to " explanation.
Old Feb 28, 2004 | 09:47 PM
crispykid717's Avatar
Bigger than Jesus
can anyone help?!?
I had this exact same problem today except mine does tilt and go back and forth except it only does it with the tilt button. weird.
Old Feb 29, 2004 | 06:44 AM
spirilis's Avatar
Procedure, at least with the 2000-
Make sure the sunroof is closed.
Disconnect battery negative cable. Press brake pedal for a few seconds (mainly to drain residual electrical system capacitance). Wait 5 minutes or so.
Reconnect battery.
Hold the sunroof tilt UP button for 5-10 seconds. It should tilt up when you first hit it, so continue to hold the button for 5-10 seconds when it's up.
Close sunroof, try the slider button. It should work.
Robert Schneeweis
Jan 11, 2017 06:47 PM
gigabyte
Jan 6, 2017 06:05 PM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
