Anyone know how to reset the moonroof?
Originally Posted by 2k3TitaniumSe
Disconnect the battery again or take it to the dealer.
the dealer is closed til mon. and if it rains, i'm screwed because it won't shut all the way.
anyone else have a suggestion?
Originally Posted by trey
Wow, can't believe nobody knew this. I found the reset intructions in the manual, just press the up or down button for more then one sec, depending if the sunroof is open or closed.
I agree, this sunroof is wierd, sometimes you slide the switch back to open and it doesn't.
Then it's open and you move the switch a couple clicks and sunroof doesn't move until till you move it to close position. Thought about taking in to dealer but probable hear the old " it's operating the way it was designed to " explanation.
I had to disconect my battery for something and now my sunroof only goes up and down but not back. in otherwords it won't open,
can anyone help?!?
can anyone help?!?
Procedure, at least with the 2000-
Make sure the sunroof is closed.
Disconnect battery negative cable. Press brake pedal for a few seconds (mainly to drain residual electrical system capacitance). Wait 5 minutes or so.
Reconnect battery.
Hold the sunroof tilt UP button for 5-10 seconds. It should tilt up when you first hit it, so continue to hold the button for 5-10 seconds when it's up.
Close sunroof, try the slider button. It should work.
Reconnect battery.
220k+ A32
Sep 22, 2015 03:08 PM
