Please Explain This One??
Old Mar 9, 2004 | 06:51 PM
Morfeus17's Avatar
Ok... Since I install my GSS342 yesterday my EGT's improved dramtically... Under full boost at 4psi, egt's are 1100F-1150F and holding.... Before it would hover at 1450F.... I guess its safe to say I'm a bit rich.... However this evening, I was cruising at around 60mph and noticed my Check Engine Light... I ran the diagnostics and got codes 9-1 and 10-1... This means Front left and right O2 sensors.... Dam that bits!!!! I hope it's a glitch in the system dued to the Higher Fuel Pressure Pump??? Perhaps the system is trying to learn??? Not sure? Because, I find it hard to believe that both Left and Right O2 sensors would go bad at the same time.... If so, **** I wish I was this lucky playing Power-Ball....
Any how, I resetted the ecu and started the car up... Trouble codes are gone for now.... I'll keep my eyes on it to see if it will pop-up...
Old Mar 9, 2004 | 08:00 PM
Julio's Avatar
Originally Posted by Morfeus17
Ok... Since I install my GSS342 yesterday my EGT's improved dramtically... Under full boost at 4psi, egt's are 1100-1150 and holding.... Before it would hover at 1450.... I guess its safe to say I'm a bit rich.... However this evening, I was cruising at around 60mph and noticed my Check Engine Light... I ran the diagnostics and got codes 9-1 and 10-1... This means Front left and right O2 sensors.... Dam that bits!!!! I hope it's a glitch in the system dued to the Higher Fuel Pressure Pump??? Perhaps the system is trying to learn??? Not sure? Because, I find it hard to believe that both Left and Right O2 sensors would go bad at the same time.... If so, **** I wish I was this lucky playing Power-Ball....
Just curious, where is your egt probe located??? 1450 would be too high if you ask me (for 4 psi anyway). Still somewhat safe as long as your probe is close to the manifold.
Old Mar 9, 2004 | 08:02 PM
subs1000w's Avatar
it could be due to the extreme richness and not being able to lean the engine out at all
you should go to a dyno to tune your A/F ratio
Old Mar 9, 2004 | 09:07 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You can ruin the 02s by running way too rich.
I know at least once that happened. Pull your plugs and you'll see.
Also, what is your setup? SC? TC? FMU ratio? Injector size? Etc?
Old Mar 9, 2004 | 10:06 PM
Julio's Avatar
Considering that he was running higher egts (lean or real rich) before the pump, and now runs cooler with more fuel, it doesnt make sense that he was running rich before.
Old Mar 10, 2004 | 02:50 AM
Morfeus17's Avatar
The probe is located at the junction between the front and rear manifolds on the reverse Y. So yes its reading both banks.. The junction location of the probe is about 10-12 inches away from the front bank.. With repect to the rear it's about 2.5 feet.
Once at 4psi the egt would show 1300F on stock fuel pump... But if sustained for a lengthy period, it will peek at 1450F... I really noticed this peak during the winter... Summer is a differnt story.
Old Mar 10, 2004 | 02:56 AM
Morfeus17's Avatar
Well considering I need to get on a dyno, its extremely difficult to guesstamate how rich is rich.... And finding a dyno in my area is tough and very costly. I'm only running 4psi though... Perhaps the system is learning due to the fuel increase...
Old Mar 10, 2004 | 03:03 AM
Morfeus17's Avatar
I'm Turbo-charged, running stock fpr and injectors. Remeber, when this check engine light ocurred, i was in vacuum running at 60-70mph for about 45 min... I did not boost the car all night... EGT's in vacuum were about 950F-1000F. Also when I did boosted the car consistantly, the car did not bogged down for one bit.. It responded very well under load... EGT's were at 1100F. But I do understand that running way to rich will ruin 02s... I'll check plugs to verify.
Old Mar 10, 2004 | 04:43 AM
plurco's Avatar
the GSS342 is the high pressure right? not the high flow. If so then the stock FPR will not be adequate.
Old Mar 10, 2004 | 05:41 AM
Stephen Max's Avatar
No, Icey means he is running rich now, from the higher fuel pressure. Running rich will cover the O2 sensors with soot and cause them to malfunction, hence the codes. You can verify this by looking at your plugs, if they are black then the O2 sensors are too.
Coincidentally, I'm going through exactly the same issue right now. The short story is I fooled around and did something to make my car run so rich that it fouled out the plugs in a day's worth of driving. I fixed the problem and changed the plugs, but now I have a CEL for the left bank O2 sensor. Time to get out the propane torch and see if the old trick about burning the soot off a sensor really works.
Old Mar 10, 2004 | 06:57 AM
Julio's Avatar
[QUOTE=Stephen Max]No, Icey means he is running rich now, from the higher fuel pressure. Running rich will cover the O2 sensors with soot and cause them to malfunction, hence the codes. You can verify this by looking at your plugs, if they are black then the O2 sensors are too.
I know what he meant. I said he is running rich (now) right in the context you quoted me from:
Besides, this wasnt in response to Icy, it was remark directed towards subs.
Old Mar 10, 2004 | 07:09 AM
Oh, sorry, I thought it was Icey that made the comment you responded to, but now I see it was subs.
But I don't see why you think he was running rich before? At 1450 F, he was just about right. I guess we're talking relative terms here. At any rate, he is definitely running way rich now if he's only seeing 1150 F when boosting.
[QUOTE=Julio]
Old Mar 10, 2004 | 07:30 AM
IceY2K1's Avatar
Do you know what FMU ratio you're running?
If you can't get to a dyno, it may be worthwhile to buy a wideband 02 like Stephen Max has.
Old Mar 10, 2004 | 07:39 AM
Julio's Avatar
I wasnt trying to imply that he was running rich before.
But as you can see here:
Sorry for being confusing, i can talk wierd sometimes.
Like me now, I am running 370's with a Z MAFS, and my egts can get real high for 8.5:1 compression not boosted. But my egt probe is right in my manifold, which makes sense seeing as how i am running rich and getting high egts
Old Mar 10, 2004 | 07:41 AM
Julio's Avatar
Like me now, I am running 370's with a Z MAFS, and my egts can get real high for 8.5:1 compression not boosted. But my egt probe is right in my manifold, which makes sense seeing as how i am running rich and getting high egts. When i had my safc in, my egts would get as much as 150* lower if not more with a 10% decrease in fuel.
All i need now is my 370 program so i dont ruin my O2 sensor and burn out my valve seals.
Old Mar 10, 2004 | 10:24 AM
Thanks, Julio, I was probably being a little dense, too.
One thing you say, though, has me puzzled. It is possible to have high egt's if you are very rich? Under what circumstances?
Old Mar 10, 2004 | 12:09 PM
Julio's Avatar
When you are running very rich, it is possible for the unburnt fuel to ignite in the manifold it self, resulting in more heat than normal. Some people retard (through certain means) their timing right before a race to spool the turbo.
Old Mar 10, 2004 | 02:07 PM
Morfeus17's Avatar
As of now I'm running stock FPR... I do have the Vortech SFMU, but not yet installed. I'm waiting on the fuel rail fitting from Srx7... As for the Wide-band 02, I will leave that option open incase the SFMU fails..
Old Mar 13, 2004 | 11:30 AM
C MAX's Avatar
im having the same damn problem. code p0155 wont go away. i took it to nissan they said my 02 is working correctly and they even changed it
they couldn't figure it out. so now there sending me to an electrician on mon, they think theres something wrong with my harness or the s/c fmu
theyre not sure...yo, morpheus hows that sfmu coming along, i'll try and link up later to see how shes running. remember your suppose to show me that turbo is the only way to go, im looking forward to seeing that baby run before you go crazy this summer with all the boost..
Old Mar 14, 2004 | 07:07 PM
Morfeus17's Avatar
Hey CMAX... Yeah... Still waiting for that fuel rail fitting from srx7... I'll keep you posted on my progress...
Old Mar 30, 2004 | 07:35 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
im having similar problems every 3weeks i get cel 0303 & ive gotten 0703 once so i guess the 02 is fouled huh....
how did that torch remedy work stephan?
Old Mar 30, 2004 | 07:55 AM
I haven't had a reoccurrence of the O2 sensor code since I fixed the rich mixture problem and reset the ecu, so I never had to try out the torch remedy. It may be worth a try, though, before spending money on new sensors, depending on how you feel about such things.
Old Mar 30, 2004 | 08:03 AM
pawnstar12's Avatar
f**k it i'll try it
DJLAX152
May 4, 2021 11:46 AM
jc53
Oct 6, 2015 06:00 AM
97_GXE
20
Sep 17, 2015 08:12 PM
jfl330
Sep 4, 2015 01:44 PM
